280 / 06 / LPG/ Problem.
Re: 280 / 06 / LPG/ Problem.
Postby simwasere » Sun Feb 20, 2011 11:16 am
http://www.youtube.com/watch?v=B8EVhFc5 ... 1391E19C22
check this out m4tty.....loads on the internet that helps use :D
simwasere
Postby M4tty » Sun Feb 20, 2011 10:10 pm
Nice one thanks. Do you know where sells them pumps to measure the map sensor? Thanks
2005 Transit 260 SWB 2.3l 16V DOHC Petrol/LPG
M4tty
Postby simwasere » Sun Feb 20, 2011 10:46 pm
Seen some on EBAY :)
simwasere
Postby M4tty » Mon Feb 21, 2011 1:13 pm
Ive had a look on ebay but cant find anything suitable. If you know what your looking for can you post a link if you dont mind please. Ill keep looking in the meantime. Thanks again for helping me out. Matt :)
M4tty
Postby simwasere » Mon Feb 21, 2011 7:37 pm
http://www.amazon.co.uk/Sealey-VS402-Va ... -1-catcorr
http://cgi.ebay.co.uk/BERGEN-TOOLS-HAND ... 3a636c45d9
Hope the links work M4tty you can also try a search for vacuum tester brake bleeder :D
simwasere
Postby M4tty » Mon Feb 21, 2011 9:39 pm
Nice one thanks mate. Much appreciated
M4tty
Postby M4tty » Wed Feb 23, 2011 9:23 pm
Hi,
Im going to clean the distributor out so ive ordered a pressure guage so i can reset the pressures after its done. Ive got to wait 14 days for Autogas2000 to get the egi distributor repair/rebuild kit (out of stock) and was going to order the filter from the same place for about £38. Its the filter which goes between the vapuriser and distributer (a sealed filter) however whilst looking on ebay I came across thishttp://cgi.ebay.co.uk/NECAM-KOLTEC-EGI- ... 3cb5570aa3 and was wondering where these 2 other filters are situated as i might aswell change them all at same time.
Thanks in advance for any replies and thanks for reading.
Cheers
Matt
M4tty
Postby mealic » Wed Feb 23, 2011 10:45 pm
Hi M4tty,before you buy those filters the one you need is about an inch long and fits at the top of the unit behind the large brass nut.I think it`s about 20mm spanner.I have a spare filter here if you need it.£6 inc p&p.I`m also putting together a manual/fact pack with diagrams of the engine and lpg system and all the info i`ve got for £12 inc p&p,it has a step by step guide and info for re-building the vaporiser VG392 which is the factory fit unit.
`04 2.3 petrol/LPG
mealic
Postby CROSSFIREROB » Wed Feb 23, 2011 10:59 pm
Your not alone Matty in being driven to the end of your teather,my stupid little green bottle still decides to start flashing at me , its very very annoying, the van is running nice , on gas , lovely jubbly ,5 or 10 minutes on the dual carrageway then out of the blue the green bottle starts flashing fast ,so i pull over and turn everything off , wait 10/20 seconds then turn back on , this doesnt always work in fact very 50/50,so i think i will have to get this booked into a FORD garage and get it plugged in to find out exactly what the problem is , one kind poster on here said it would be the heat sencer , which is sound advice but i cant just change everything until its works, i may aswell sell the van on in that case , and i dont want to as its a very clean van.
Do i have to disconect the battery since i put a new RPM Filter on ?, because i didnt do that in case i lost my radio,i dont have the code.
Rockin and a rollin all day long !
CROSSFIREROB
Postby simwasere » Wed Feb 23, 2011 11:30 pm
no good taking it to ford they no s**t about there own factoy fitted gas system useless. :?
simwasere
Postby mealic » Wed Feb 23, 2011 11:34 pm
CROSSFIREROB wrote:Your not alone Matty in being driven to the end of your teather,my stupid little green bottle still decides to start flashing at me , its very very annoying, the van is running nice , on gas , lovely jubbly ,5 or 10 minutes on the dual carrageway then out of the blue the green bottle starts flashing fast ,so i pull over and turn everything off , wait 10/20 seconds then turn back on , this doesnt always work in fact very 50/50,so i think i will have to get this booked into a FORD garage and get it plugged in to find out exactly what the problem is , one kind poster on here said it would be the heat sencer , which is sound advice but i cant just change everything until its works, i may aswell sell the van on in that case , and i dont want to as its a very clean van.
I think you should disconnect the battery or at least remove the two fuses under the tray on the passenger side to re-set the system.You can get radio code if it`s ford radio on this forum.
`04 2.3 petrol/LPG
mealic
Postby mealic » Wed Feb 23, 2011 11:37 pm
Where are you based Crossfirerob?
`04 2.3 petrol/LPG
mealic
Postby CROSSFIREROB » Thu Feb 24, 2011 11:16 am
Liss mealic, GU337BB.
Thanks for the advice guys, this all may sound trivial to a lot folk looking in , but i can tell you it driveing me crazy, ive bought a nice clean van and as daft as it sounds i really like the van , it drives like a car and is comfy , i didnt expect to have issues with it though,i was tricked by the seller , his answer was " oh we never used the gas ", and to be honest the only issue is the LPG, which kinda pisses me off because LPG is why i bought the van, i would have gone Diesal otherwise.I must sort the van about before i go mad ,and end up on the front page of the Sun :mrgreen:
CROSSFIREROB
Postby CROSSFIREROB » Thu Feb 24, 2011 7:32 pm
I have disconected the battery and reconnected it :
CROSSFIREROB
Postby M4tty » Thu Feb 24, 2011 10:09 pm
Did you leave it disconnected for a while rob? Has it achieved anything? ive got to wait 2 weeks for a rebuild kit for the vapouriser then hoping that will sort the problem. Hopefully. Were get there in the end mate!! :)
M4tty
