DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby nmartin546 » Tue Oct 03, 2017 11:15 pm
Hi could you tell me mine please reg is ak53dlv thanks
nmartin546
Postby chris_ » Wed Oct 04, 2017 2:09 am
i couldn't expand the minor list either. i copied the items from html source code..
Transit 2000-2006, 2.0L Duratorq TDCI (125PS), Diamond White 73
VIN Number: WF0VXXBDFV3S09849
Registration Number: AK53DLV
First Registration Date: 01.09.2003
Registration Country: GB
Primary Features
Build Date: 17.07.2003
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 280S Series
Engine: 2.0L Duratorq TDCI (125PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-I-C)
Minor Features
<li><span>&nbsp;With Low Roof</span></li><li><span>&nbsp;With Rear Mudflaps</span></li><li><span>&nbsp;With Front Mudflaps</span></li><li><span>&nbsp;With Half Vertical Mesh Partition</span></li><li><span>&nbsp;LH Sliding Side Cargo Door - Low</span></li><li><span>&nbsp;With Hinged Rear Loading Doors</span></li><li><span>&nbsp;Southampton Plant Built</span></li><li><span>&nbsp;Marketing Flex Prep Pack 7</span></li><li><span>&nbsp;Less SVO Application/Label</span></li><li><span>&nbsp;Marketing Level 3</span></li><li><span>&nbsp;With Power Front Windows</span></li><li><span>&nbsp;With All Light Tinted Glass</span></li><li><span>&nbsp;With Rear Blanking Panel</span></li><li><span>&nbsp;With Heated Windscreen</span></li><li><span>&nbsp;Less Heated Rear Window</span></li><li><span>&nbsp;Less Header Mounted Package Tray</span></li><li><span>&nbsp;With Complete Rear Hardboard Trim</span></li><li><span>&nbsp;With Partial Headlining - Moulded</span></li><li><span>&nbsp;With Roof Height Feature Pack 1</span></li><li><span>&nbsp;With Door Map Pocket</span></li><li><span>&nbsp;With Front Roof Grab Handle</span></li><li><span>&nbsp;With Load Space Tie Down Loop</span></li><li><span>&nbsp;With Cargo Stowage Rail (Mid)</span></li><li><span>&nbsp;Drivers Door Trim - Level 2</span></li><li><span>&nbsp;Passenger Door Trim - Level 1</span></li><li><span>&nbsp;Less Rear View Mirror</span></li><li><span>&nbsp;Drivers Short Arm Power Mirrors</span></li><li><span>&nbsp;Passenger Short Arm Power Mirror</span></li><li><span>&nbsp;Seat Pack 8</span></li><li><span>&nbsp;With Drivers Seat Fixed Armrest</span></li><li><span>&nbsp;Less Passenger Seat Armrests</span></li><li><span>&nbsp;With Passenger Seat Valance</span></li><li><span>&nbsp;Less Temp Control Driver Seat</span></li><li><span>&nbsp;Less Temp Control Passengers Seat</span></li><li><span>&nbsp;With Driver 6 Way Mnl.Seat Adjuster</span></li><li><span>&nbsp;Less Adjustable Passenger Seat</span></li><li><span>&nbsp;Fleet Key</span></li><li><span>&nbsp;With Door Dead Locks</span></li><li><span>&nbsp;Remote Control Door Entry - 2 Fob</span></li><li><span>&nbsp;Less Rear Window Wiper/Washer</span></li><li><span>&nbsp;With Driver Air Bag</span></li><li><span>&nbsp;With Spare Tyre Security Package</span></li><li><span>&nbsp;With Single Rear Wheels</span></li><li><span>&nbsp;5 1/2J x 15 Steel Wheel</span></li><li><span>&nbsp;195/70R 15C LI 100/98 BSW</span></li><li><span>&nbsp;Partial Wheel Covers</span></li><li><span>&nbsp;Less Engine RPM Control</span></li><li><span>&nbsp;4 Wheel Anti-Lock Braking System</span></li><li><span>&nbsp;Less Rear Seat Climate Control</span></li><li><span>&nbsp;With Recirculating Heater</span></li><li><span>&nbsp;Less Rear Compartment Heating</span></li><li><span>&nbsp;With MPH/KMH Speedometer</span></li><li><span>&nbsp;With Radio Pre-Equipment Pack 1</span></li><li><span>&nbsp;6000CD RDS EON</span></li><li><span>&nbsp;With Front Fog Lamps</span></li><li><span>&nbsp;With Load Compartment Lamp</span></li><li><span>&nbsp;Less High Mounted Stop Lamp</span></li><li><span>&nbsp;With Front Headlamp Levelling</span></li></ul>
MK 7.5 12plate - 125hp 2.2TDCI - FWD LHD SWB LR - 9 seats, windows and lots of toys :) --> southampton built and rescued from france
chris_
Postby tylermonk » Wed Oct 04, 2017 7:20 am
Hi just purchased a Transit Connect 1.6 2014 reg MW14 FJX and I could do with some info on it so I know where I am.
Cheers
Tyler
tylermonk
Postby Punto443 » Wed Oct 04, 2017 8:22 am
tylermonk wrote:Hi just purchased a Transit Connect 1.6 2014 reg MW14 FJX and I could do with some info on it so I know where I am.
Cheers
Tyler
Transit/Tourneo Connect 2013-, 1.6L Duratorq CR TC (75PS) - DV6, Frozen White
VIN Number: WF04XXWPG4EJ42285
Registration Number: MW14FJX
First Registration Date: 27.06.2014
Type Approval Number (TAN): e1*2001/116*0207 / e1*2007/46*0272
Primary Features
Build Date: 08.05.2014
Vehicle Line: Transit/Tourneo Connect 2013-
Body Style: SWB DCIV
Version: Series 300V
Engine: 1.6L Duratorq CR TC (75PS) - DV6
Transmission: 5-Speed Manual Trans - MTX75
Drive: RHD FWD
Axle Ratio: 3.56 Final Drive Ratio
Emission: Stage V LDT2 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Fabric: Traxon/Max Charcoal Black
Minor Features
Less Underbody Protection
Less Roof Line Conversion
Less Roof Wiring Hole
Less Accessory USB Unit
With Front Fascia - Level 2
Less Front Mudflaps
With Dual Side Load Doors
With Hill Launch Assist
With Full Mesh Bulkhead
With 180° Cargo Door Check Arms
Cargo Tie Down Hooks-Inside
Max Payload Upgrade Pk
(-) Version Packages
Less Special Purpose Vehicle
Valencia Plant Built
Less Special Equipment Package
Complete Vehicle
Less Marketing Flex Prep Pack
Less Special Order Paint
Less Functional Upgrade Pack
Marketing Level 1
Less Dress Up RSO
(-) SVP
Exterior Paint - Solid
Less VP Application Label
Less Water Wading Equipment
Kit - Tyre Repair Service
Less Rear Package Tray
Less Global/Auto Closing
Power Frt Window-1 Tch Dwn-Dr Only
Less Rear Side Window
With Normal Tinted Glass
Grille - Upper Bars Dk Self Colour
Non Infra Red Refl Windscreen
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
Less Rear Window
Less Heated Windscreen
Less Rr Seat Overhead Console
Less Glove Box Lid
Less Mid-Veh Overhead Console
Base Center Console
Cup Holders (2) - Row 1
Int Environment Clr-Charcoal Black
Int Feat Colour - Charcoal Black
Side/Rear Door Trim Panel-Level 3
Less Front Floor Mats
Less Rear Floor Mats
Floor Cover - Rubber Ins-Partial
With Instrument Panel Stowage Box
Drivers Visor Mir/Flap/Tick Pocket
Sunvisor Less Mirror - Passenger
With Black Interior Door Handles
With Level 1 Door Trim Panel
Less Rear Interior Assist Handle
Rear Coat Hook
PVC Door Armrest
Less Rr Interior Overhead Stowage
Less Luggage Compartment Net Kit
Less Load Retention Net
With Load Floor Clover
Less First Aid Retain Straps
Less Cargo Stowage Rack/Rail
Interior Grab Handles - Front
Less Interior Partition
Less Driver Roof Storage
With Self Colour Grille No.1
Less Active Grilleshutter
Less Roof Rack
With Wide Body Moulding
Less Rear Window Protector
Manual Dual Mirror-Manual Fold Back
With Self Colour Ext Mirror Finish
Large Rear View Mirror Housing
Less Driver Seat Back Map Pocket
Less Passenger Seat Back Map Pocket
Seat Pack
Less Drivers Seat Armrest
With Front 2 Way Headrest
With Driver Seat Recliner - Rotary
With Passenger Seat Recliner-Rotary
Less Tray/Table - Front Seat
Less Rear Seat Centre Armrest
Less Driver Seat Lumbar Support
Less Passenger Seat Lumbar Support
Less Under Seat Stowage - Driver
St Belt Minder-Drvr/EU Tel&Snd
2nd Row Seat 60/40 (3 P) - Folding
Less 3rd Row Rear Seat
With Driver 2 Way Mnl. Seat Adjust
With Pass 2 Way Manual Seat Adjust
Less Trailer Towing Attachments
Less Trailer Coupling
Less Trailer Towing Hitch
Less Towing Pre-Pack
Less Trailer Sway Control (TSC)
Less Fuel Economy Pack
Exterior Door Handle-Self Coloured
With Self Coloured Tailgate Handle
Ignition Key Combination Pack 1
With Urethane Gear Shift Knob
With Child Proof Safety Lock
Less Fleet Key
Less Keyed Alike Options
With Door Auto Relocking - Enabled
Less Configurable Unlocking
Frequency - 433MHZ
Less Power Lock Group
With Door Entry Remote Control Unit
Less Keyless Entry System
With Variable Intermittent Windscreen Wiper
Less Heated Washer Jet
Less U/Body Corrosion Protect
Self Colour Rear Bumper End Caps
Plastic Front Bumper
Rear Bumper - Self Colour
Less Front License Plate Bracket
Less Restraint Devices
Less Thermoplastic Kneebolster Sys
Less Air Curtain Restraint
Less Air Curtain Restraint RH
Less Rear Side Air Bag Restraint
With Inertia Front Seat Belt
With Rear Seat Belts 2nd/3rd Row
With Driver Air Bag
Less Passenger Air Bag
Less Side Air Bag - Drivers Side
Less Side Air Bag - Passenger Side
Less Passenger Air Bag Deactivation
Less Isofix Hard Point Attach
With Manual Adjust Frt.S.Belt Mount
Less Spare Wheel
Less Tyre Pressure Sensors
6.5 X 16" Steel Road Wheel
205/60R16
With Standard Tyre Tread - Front
With Standard Tyre Tread - Rear
Any Brand Tyre Vendor
With Wheel Hub Cap
Non Locking Lug Nuts
Less Engine Block Heater
Less MPH Engine Governor
Cold Start -25 Deg C
Standard Electric Starter Motor
Less Remote Starter
Solid Flywheel
With 4 Wheel Disc-Brake
Less Low Speed Safety System
With IVD/Traction Control/ABS
Less In-Dash Internet Device-FIA
Less Tracking System - FIA
Front Lip Spoiler - FIA
3.80/2.048/1.258/0.865/0.674
Less Manual Shift Auto Trans
Standard Front Seat
With Rear Duct / B-Pillar
Less Air Purifier Sensor
With Ptc Heater
With Diesel Fuel Capability
Less Gaseous Prep Pack
With Fixed Foot Pedals
With Manual Tilt/Slide Stg Column
With Deluxe Steering Wheel
Less Speed Control
Less Auxiliary Heater
With Conventional Instrumentation
With Instrument Cluster - Rheostat
With Trip Computer
Dual Note Electric Horn
Less Tyre Inflation Monitor
Less Compass Display
Less Multi Function Display
Less Navigation Data
Less Emergency Call Button
Less Lane Departure Warning System
Less Driver Impairment Monitor
Less Blind Spot Information System
Less Lane Keeping Aid
Less Anti-Theft Alarm
With Safeguard Anti-Theft Sys(Pats)
Less Rear Parking Aid
Less Front Parking Aid
Standard Duty Battery
Less Power Convertor
With A/V Jack
Ultra Low Audio+USB+BT+DAB
Ice Feature Pack 2
Less Diversity Antenna
Less Integrated Control Panel
With 2 Speakers
Microphone
Less Sync
With Steering Wheel Radio Controls
Less Steering Wheel MFD Controls
Electrical Outlet
Less Smokers Package
12V Aux Power Point In I/P
Less Power Point Plug - Rear
Less Camera
Overhead Pod 1
Less Auto Headlamps
With Black Fog Lamp Bezel
With Halogen Headlamp
With Daytime Running Lamps
Less Headlamps - Wiper Activated
Less Front Fog Lamps
With Black Headlamp Bezels
With Header Courtesy Light
With Rear Overhead Courtesy Lamp
Less Glove Box Illumination
Less Load Compartment Lamp
With High Mounted Stop Lamp
With Rear Fog Lamps
Less Headlamp Control
Less Wiring Harness
Less Auxiliary Fuse Panel
There are more minor features for this vehicle, click to expand this list.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby nmartin546 » Wed Oct 04, 2017 10:27 am
Can u tell me details for ak53dlv please
nmartin546
Postby Punto443 » Wed Oct 04, 2017 4:08 pm
nmartin546 wrote:Can u tell me details for ak53dlv please
Primary Features
Series: 280S Series
Drive: RHD FWD
Axle Ratio: 4.23
Territory: (+)"GB"
Minor Features
With Low Roof
With Rear Mudflaps
With Front Mudflaps
Marketing Level 3
Seat Pack 8
Fleet Key
With Driver Air Bag
6000CD RDS EON
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby ian mk6 » Thu Oct 05, 2017 9:10 pm
Hi, could someone please do MK56 RLY?
Thanks, Ian.
ian mk6
Postby loot » Thu Oct 05, 2017 9:20 pm
ian mk6 wrote:Hi, could someone please do MK56 RLY?
Thanks, Ian.
We are sorry, but no information could be found for the VIN/Registration number you entered - MK56RLY
Have you got a vin number?
Ids map here
loot
Postby ian mk6 » Thu Oct 05, 2017 9:29 pm
Not at the moment sorry. It`s a scrapper i want the gearbox out of but wanted to check the box ratio.
Thanks for trying though, will try to confirm the reg or get the vin off the guy.
ian mk6
Postby ian mk6 » Fri Oct 06, 2017 12:24 pm
Thanks, Ian.
Hi, the vin is wf0xxxbdfx6u32723.
Thanks.
ian mk6
Postby loot » Fri Oct 06, 2017 3:29 pm
ian mk6 wrote:
Thanks, Ian.
Thanks.
Primary Features
Build Date: 20.06.2006
Vehicle Line: Transit 2006-2014
Series: 260S Series
Engine: Duratorq TDCI 2.2 (85PS)
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
I can't expand the minor features on my phone they've changed the web page layout :?
No outstanding recalls tho.
Ids map here
loot
Postby Matt246801 » Fri Oct 06, 2017 4:21 pm
ST07ZFM
Matt246801
Postby ian mk6 » Fri Oct 06, 2017 7:38 pm
Have you got a vin number?[/quote]
Thanks.[/quote]
Primary Features
Series: 260S Series
Drive: RHD FWD
Axle Ratio: 4.23
Territory: (+)"GB"
Paint: Frozen White
No outstanding recalls tho.[/quote]
Thanks loot. Much appreciated.
ian mk6
Postby tylermonk » Sun Oct 08, 2017 1:21 pm
Cheers
Tyler
Primary Features
Drive: RHD FWD
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Minor Features
Less Front Mudflaps
Complete Vehicle
Marketing Level 1
Less Dress Up RSO
(-) SVP
Less Rear Window
Less Glove Box Lid
Base Center Console
Rear Coat Hook
PVC Door Armrest
Less Roof Rack
Seat Pack
Less Fleet Key
Frequency - 433MHZ
With Driver Air Bag
Less Spare Wheel
205/60R16
With Wheel Hub Cap
Less Remote Starter
Solid Flywheel
Standard Front Seat
With Ptc Heater
Less Speed Control
With Trip Computer
With A/V Jack
Ice Feature Pack 2
With 2 Speakers
Microphone
Less Sync
Electrical Outlet
Less Camera
Overhead Pod 1
Less Auto Headlamps
With Rear Fog Lamps
Less Wiring Harness
Awesome man thanks
tylermonk
Postby Lynes6098 » Sun Oct 08, 2017 5:15 pm
Could someone please supply the ETIS details for my van AT57JSY
Lynes6098
