DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby antcull » Thu Nov 30, 2017 3:28 pm
RayTrans wrote:Hi all, looking for some info about WF0FXXTTFFCC55628 white flat bed 2012 a friend has just bought it, cheers & thanks Ray
Transit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Frozen White
VIN Number: WF0FXXTTFFCC55628
Registration Number: LG62WWR
First Registration Date: 24.10.2012
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 23.07.2012
Minor Features
With Low Roof
Less Roof Line Conversion
Less Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Less Side Load Doors
With Diesel Particulate Filter
Less Back Panel Bulkhead Grille
With Unperforated Cab Back Panel
Less Bulkhead
Less Rear Cargo Door
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Otosan (Turkey) Plant Build
Less Special Equipment Package
Incomplete - Ship To VFS
Less Marketing Flex Prep Pack
Less Sales Badge
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Less Paint Package
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Fixed Rear Window
Less Rear Side/Back Security Glass
With Heated Windscreen
Less Heated Rear Window
Less Overhead Console
Less Header Mounted Package Tray
Less Rear Compartment Trim Panel
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
Less Load Compartment Loops
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
Less Exterior Body Mouldings
Less Rear Window Protector
Less Rear Step
With Dipping Rear View Mirror
Large Head/Long Arm Mirror
Manual Dual Mirror-Manual Fold Back
Less Seat Construction
Less Rear Underseat Stowage Bin
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Zonal Opposite Door Relocking
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rain Sensor - Front W/Wiper
Less Sun Roof
Less Rear Sunroof
Mid Grey Front Bumper
Less Rear Bumper
Less Rear Bumper Under Run
Less Bumper Underrun - Front
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
Less Spare Tyre Lock
With Double Rear Wheels
5 X 16" Steel Wheel
Less Wheel Covers
Non Locking Lug Nuts
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Stage V LDT3 Emissions
Solid Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Less Tachograph
Less Tripminder Assy
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Extra Heavy Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Less Voice Activated Modules
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
With Daytime Running Lamps
Less Front Fog Lamps
With Roof Marker Lamps
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
Less High Mounted Stop Lamp
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Front Headlamp Levelling
Less Headlamp Control
Less Instrument Panel Dimmer Switch
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
There are more minor features for this vehicle, click to expand this list.
2005 90 T350 LWB HR
antcull
Postby antcull » Thu Nov 30, 2017 3:31 pm
Primary Features
Vehicle Line: Transit 2006-2014
Cab Style: Single Cab (2 Door)
Series: 1.7-350L Series
Engine: 2.2L CR TC I4 DSL 125 PS
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.58
Emission: Stage V LDT3 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G
2005 90 T350 LWB HR
antcull
Postby antcull » Thu Nov 30, 2017 3:33 pm
Barr wrote:HI COULD SOMEONE TELL ME THE PS FOR GK52 YHC Thanks
We are sorry, but no information could be found for the VIN/Registration number you entered - GK52YHC
2005 90 T350 LWB HR
antcull
Postby antcull » Thu Nov 30, 2017 6:26 pm
Daddo330 wrote:Hi
Recently purchased this van Reg No YR11 WPX can you please list details from ETIS.
Much Appreciated.
Transit 2006-2014, Duratorq TDCI 2.2 (85PS), Frozen White
VIN Number: WF0XXXTTFXAA85368
Registration Number: YR11WPX
First Registration Date: 11.04.2011
Primary Features
Build Date: 25.11.2010
Cab Style: Regular Cargo Van
Series: 260S Series
Engine: Duratorq TDCI 2.2 (85PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Fabric: Tomy (G-C)
Minor Features
With Rear Mudflaps
Less Interior Pack
With Kerbside Side Load Doors
Less Diesel Particulate Filter
With Full Partition
Less Second Unit Body
Marketing Level 3
With Tool Kit
With Rear Blanking Panel
With Load Space Tie Down Loop
Less Rear View Mirror
Large Head/Short Arm Mirror
With Spare Tyre Security Package
Less Bluetooth
Ice Feature Pack 5
With High Mounted Stop Lamp
2005 90 T350 LWB HR
antcull
Postby ShipAhoy » Fri Dec 01, 2017 8:13 am
I too just purchased a transit which is the base for a motorhome in Australia. Would someone look up on etis the configuration. I have the rego but not the VIN yet. Australian plate is 577KBP
Many thanks!
ShipAhoy
Postby Jay_today » Fri Dec 01, 2017 7:45 pm
Hi,
Can one of you wonderful folk give me the details for LC52 KZK please?
Jay_today
Postby dumper » Fri Dec 01, 2017 9:42 pm
Hi all can anyone do check on transit 17 seat bus looking for one to turn into a campervan seen one on eBay and auto Trader it’s a private sail reg is LM15 XFE thanks
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby dumper » Fri Dec 01, 2017 9:51 pm
Forgot to put on does ettis give any details on service and recalls it’s had and any outstanding cheers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby MK7 user » Sun Dec 03, 2017 11:10 am
ShipAhoy wrote:I too just purchased a transit which is the base for a motorhome in Australia. Would someone look up on etis the configuration. I have the rego but not the VIN yet. Australian plate is 577KBP
Many thanks!
G'day mate. :D
An Ozzie rego plate is never going to work on a European built van. :!: :mrgreen:
No Squire, not just any van....it has to be a Mk7 (VM.1) :D
MK7 user
Location: Grim HQ in the parish of Aston Nr the Great Hall
Postby MK7 user » Sun Dec 03, 2017 11:17 am
Jay_today wrote:Hi,
Sorry dude....wonderful folk will be at Church on the Sabath....so you're stuck with me. :P
Transit 2000-2006, 2.0L Duratorq DI (75PS), Diamond White 73
VIN Number: WF0VXXBDFV2A64833
Registration Number: LC52KZK
First Registration Date: 20.01.2003
Primary Features
Build Date: 19.11.2002
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van LCF
Series: 300S Series
Engine: 2.0L Duratorq DI (75PS)
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Air Conditioning:
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-H-C)
No Minor Features are listed in Etis. :(
MK7 user
Postby MK7 user » Sun Dec 03, 2017 11:30 am
dumper wrote:Hi all can anyone do check on transit 17 seat bus looking for one to turn into a campervan seen one on eBay and auto Trader it’s a private sail reg is LM15 XFE thanks
Hey-up dumper. :D
There is a new Etis up & running....some of the information that used to be available free of charge has been moved to the "Subscription menue", it's currently showing the "Oasis server" is off-line, I'm not sure if that means the server is down or you need to pay the subscrition to access the recall & service info. :?
Transit 2014-, 2.2L CR TC I4 DSL 135PS, Deep Impact Blue (Metallic)
VIN Number: WF0HXXTTGHFD13198
Registration Number: LM15XFE
First Registration Date: 30.04.2015
Primary Features
Build Date: 05.03.2015
Vehicle Line: Transit 2014-
Cab Style: Bus (M2)
Series: 460 E Series
Engine: 2.2L CR TC I4 DSL 135PS
Drive: RHD RWD
Axle Ratio: 3.31
Emission: Heavy Duty Truck Euro 6 Rqmts
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: Deep Impact Blue (Metallic)
Interior Fabric: Lane/Max Charcoal Black
Minor Features
With High Roof
With Rear Mudflaps
Accessory Media Hub 1XUSB
With Front Mudflaps
With Hill Launch Assist
Less Bulkhead
270 Dgr Rr Cargo Dr (Mag Dr Ret)
Side Loading Dr Opening-Restricted
Complete Vehicle
Less Sales Badge
Less Special Order Paint
With Power Equipment Group 3
Marketing Level 4
With Visibility Pack High
Exterior Paint - Solid
Less Cooling Pack
Less VP Application Label
European Environmental Label
Less SVO Marketing Packs
With Fire Extinguisher F (2L)
With Tool Kit
With First Aid Kit
Power Front Windows One Touch Up/Do
With Privacy Glass
With RH 2nd Row Sliding Window
With LH 2nd Row Sliding Window
With RH 3rd Row Fixed Window
With LH 3rd Row Fixed Window
Flip Open 4th Row RHS Window
Flip Open 4th Row LHS Window
With Heated Rear Window
Less Console Ashtray
With Locking Glove Box Lid
With Standard Overhead Console
Interior Environment Colour-Pewter
Int Feat Colour - Charcoal Black
Side/Rear Door Trim Panel-Level 2
Interior Trim Accent Pack B
With Rubber Floor Covering
With Full Headlining - Moulded
Sunvisor Less Mirror - Drivers
Sunvisor Less Mirror - Passenger
Rear Coat Hook
With A Pillar Assist Handle
With B Pillar Assist Handle
Less Rr Interior Overhead Stowage
First Aid Retain Strap
Less Interior Grab Handles
Less Interior Partition
Roof Storage-Driver Sunglasses
With Grey Grille
Wide Bodyside Moulding-Grey
Side Step - Power
Less Side Load Door Power Side Step
Electro Mirr W/Rr View Cam Display
Dual Ext Pwr Mirror-Power Fold Back
Less Auto Dipping Mirror System
With Drivers Seat Armrest
With Front 2 Way Headrest
Tray/Table - Front Seat
With 2 Way Adjustable Rear Headrest
With Rear Seat Centre Armrest
With Manual Rear Seat Recliner
With Drivers Manual Lumbar Support
Less Passenger Seat Lumbar Support
Sixth Row Quad Seat
With Drivers Heated Seat
With Heated Passenger Seat
St Belt Minder-Drvr/EU Tel&Snd
Second Row Dual Seat
With 3rd Row Single/Double Seat
With 4th Row Single/Double Seat
With 5th Row Single/Double Seat
With Driver 10 Way Pwr Seat Adjust
With Pass 2 Way Manual Seat Adjust
Less Trailer Sway Control (TSC)
Emergency Hammer
Less Fuel Economy Pack
Exterior Door Handle - Black
Lift/Bootlid Handle Exterior-Black
With Leather Gear Shift Knob
Less Fleet Key
Configurable Unlocking - Conf 2
With Central Locking System
Remote Control Door Entry - 2 Fob
Less Keyless Entry System
With Automatic Windscreen Wiper
Less Headlamp Washer/Wiper
Washer Tank Level Warning Lamp
With Rear Tilting Roof
Less U/Body Corrosion Protect
Less Bodyside Accent Stripe
Front Bumper - Partial Body Colour
Rear Bumper - Plastic Unpainted
Less Front License Plate Bracket
With Front Bumper Under Run (N2)
Air Curtain Restraint LH
Air Curtain Restraint RH
Less Beltminder
With Inertia Front Seat Belt
With Rear Generation Seat Belts
With Driver Air Bag
With Passenger Air Bag
With Passenger Air Bag Deactivation
With Isofix Hard Point Attachment
Seat Belt Pretensioner - Drivers
Drv/Pass Seat Mounted Side Airbags
Less Tyre Pressure Sensors
6.0 X 16" Steel Wheel
With Mini Centre Cap Steel Wheels
100KPH/62MPH Engine Governor
Starter - Stop/Start System
Front Axle Rating-Maximum
Less Brake Dust Shields
With Mechanical Parking Brake
Collision Mitigation System
Less Brake Emergency Assist
Brakes-ESP/HLA/FBS
Less Tracking System - FIA
Less Transfer Case
With Rear Seat Climate Control
With Pollen Filter
With Ptc Heater
A/C Refrigerant-R134A
Less Auxiliary Fuel Ports
Non Locking Capless Fuel Fill
Fuel Tank Fill Neck-With Inhibiter
With Manual Tilt/Slide Stg Column
Leather Steering Wheel
Electronic Speed Limiting Device
With Adaptive Speed Control
With Rear Compartment Heating
Conventional Instruments - Level 2
With Instrument Cluster - Rheostat
With Digital Tachograph
With Trip Computer
Dual Note Electric Horn
Matrix Multi Function Display
Less Navigation System
Less Emergency Assistance
Less Revers Gear Alarm
Less Lane Departure Warning System
Less Driver Impairment Monitor
Less Speed Sign Recognition
Less Vehicle Tilt Sensing
With Rear Parking Aid
With Front Parking Aid
Heavy Duty Battery
With A/V Jack
ICE- Low Audio (0C)
Ice Feature Pack 4
Midline ICE ICP
Radio Speakers-2 Woofers/2 Tweeters
Microphone
With Media Gateway Module
With Steering Wheel Radio Controls
Less Steering Wheel MFD Controls
Less Electrical Outlet
With Power Point Plug - Rear
Rr View Camera W/Mirror Display
Less Safe Deposit Box
Dual Rear Wheel Pack 2
With Auto Headlamps
With Halogen Headlamp
Headlamps-Static Bending
With Front Fog Lamps
Rear Door Edge Warn Reflectors
Less Cornering Lamp
With Footwell Lights
Header Mounted Courtesy/Maplights
Diming Rr Courtesy Lamp W/Map Light
Less Glove Box Illumination
With Load Compartment Lamp
With Side Marker Lamps
With Rear Fog Lamps
With Automatic Headlamp Control
Less Wiring Harness
© Ford Motor Company Ltd
MK7 user
Postby dumper » Sun Dec 03, 2017 11:56 am
Thanks for that mk 7 user
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby MK7 user » Mon Dec 04, 2017 1:57 am
dumper wrote:Thanks for that mk 7 user
She's back up & running dude. :D
Outstanding Field Service Actions
16B05 - TRANSIT OIL FILLER CAP SEPARATION
16B25 - TRANSIT M2 BUS CHILD LOCKS
The service functions available are to generate a tick sheet & service schedule at xx miles - not the Service History.
MK7 user
Postby ShipAhoy » Mon Dec 04, 2017 6:12 am
Thanks MK7 user,
It was a long shot with the Aussie rego. I got the VIN from the previous owner. VIN # WFOAXXTTFA4G31049. Hopefully that will work in etis.
ShipAhoy
Postby MK7 user » Mon Dec 04, 2017 11:37 pm
ShipAhoy wrote:Thanks MK7 user,
G'day mate. :D
You'll probably need to use the Vin at some point when ordering parts & such like....be aware that the 'O' should be an '0' (zero).
Outstanding Field Service Actions: No Campaign Message(s) found
Transit(Turkey)2001, 2.4L Duratorq (85kW/115PS), Diamond White 73
VIN Number: WF0AXXTTFA4G31049
Primary Features
Build Date: 09.04.2004
Vehicle Line: Transit(Turkey)2001
Series: 350E Series
Engine: 2.4L Duratorq (85kW/115PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Territory: (+)"AUS"
Interior Fabric: Stylize (-B-C)
Minor Features
With Low Roof
With Rear Mudflaps
With Front Mudflaps
With Wide Aluminium Side Float
Increased 4250KG GVM Rating
With SVO Application/Label
Marketing Level 3
With Roof Height Feature Pack 3
With Front Roof Grab Handle
Passenger Lrg Head/Long Arm Mirror
With Passenger Seat Fixed Armrests
With Pass 4 Way Manual Seat Adjust
With Rear Bumper Under Run (N2)
With Driver Air Bag
With Side Underrun Rails
Less High Centre of Gravity Pack
Type 53 Rear Axle 5720lb(2600 Kg)
Less Anti-Spin Traction System
Standard Front Seat
With Manual Clutch
With KMH Speedometer
Heavy Duty Alternator
With Radio Pre-Equipment Pack 1
6000CD RDS EON
With Smokers Package
With Rear Marker Lamps
MK7 user
