How to add factory cruise on a mk7 transit no pics
Re: How to add factory cruise on a mk7 transit+pics
Postby Rumble bee » Fri Feb 21, 2014 9:42 pm
Done 8/9 wheel changes without disconnecting the battery and I still clench taking it off :lol:
Rumble bee
Postby Rumble bee » Fri Feb 21, 2014 9:49 pm
Vid of the message,
Rumble bee
Postby soprano1982 » Fri Feb 21, 2014 9:50 pm
Rumble bee wrote:Done 8/9 wheel changes without disconnecting the battery and I still clench taking it off :lol:
Haha :lol: must admit - even tho I'd disconnected the bat I still found myself angling the bag away from myself :)
soprano1982
Postby limitedblack » Fri Feb 21, 2014 10:01 pm
I'm taking all my extra functions off, like cruise, aircon, computer. Trying to be different, and I will soon be the only one without all this ;)
Happy Easter
limitedblack
Postby mk7newbie » Fri Feb 21, 2014 10:33 pm
Will unplugging the plug below steering wheel be safe enough for airbag not to go off!!!
mk7newbie
Postby loot » Fri Feb 21, 2014 10:38 pm
That plug will cut all power yes, it's the reconnecting that is the worrying part even tho no power goes to the airbag unless a crash sensor is set off our the srs tells it to, still, it is a tense moment!
Chris, what are you doing with the wires to change the message? And do you think it would stay like that if you set it and locked the doors etc?
I did the horn beeping but it was wired up lol.
Ids map here
loot
Postby Rumble bee » Fri Feb 21, 2014 10:51 pm
Just making and breaking the contacts with the horn disconnected under the bonnet :D
Rumble bee
Postby loot » Fri Feb 21, 2014 10:58 pm
So me beeping the horn would have done it?
Ids map here
loot
Postby Tango330 » Fri Feb 21, 2014 11:08 pm
loot34 wrote:That plug will cut all power yes, it's the reconnecting that is the worrying part even tho no power goes to the airbag unless a crash sensor is set off our the srs tells it to, still, it is a tense moment!
Ooops, that is the only bit I didn't worry about :shock:
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby Rumble bee » Sat Feb 22, 2014 8:26 am
loot34 wrote:So me beeping the horn would have done it?
Yeah should've done it. Maybe it's special like me :mrgreen:
Rumble bee
Postby loot » Sat Feb 22, 2014 9:11 am
I suppose it doesn't work on the older clocks then :-(
Great info for ppl wanting it who have later clocks.
Although, if you live somewhere where you feel the rage on a daily basis driving through town, your clocks will have an identity crisis :lol:
Ids map here
loot
Postby mk7newbie » Sun Feb 23, 2014 9:06 am
Having put cruise control steering wheel on and screwing back shroud any ideas what the extra plug taped up near radio control stalk is??? It seems to come from the plug that the cruise control and horn wires come from?
Loot does the green cruise light only come on when activated??
mk7newbie
Postby loot » Sun Feb 23, 2014 9:23 am
Yes, when you get the software sorted the cruise lamp comes on and goes off with the ignition switched on, same as the other warning lamps :wink:
Ids map here
loot
Postby mk7newbie » Sun Feb 23, 2014 9:32 am
loot34 wrote:Yes, when you get the software sorted the cruise lamp comes on and goes off with the ignition switched on, same as the other warning lamps :wink:
Great was getting a little worried for a second! Any ideas on the extra plug under column near radio controls??
mk7newbie
Postby loot » Sun Feb 23, 2014 9:33 am
Not sure as my basic wiring is just that lol, have you got a picture? :D
Ids map here
loot
