Idiots guide to IDS
Re: Idiots guide to IDS
Postby tibsy » Thu Feb 12, 2015 11:41 pm
just did a "dvd" test with fully charged battery,- after 2 hrs continuos play it had 19% remaining! so, in better condition than i thought.
should be ok as long as "ids"program doesn`t suck more juice than playing a dvd!?
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby loot » Thu Feb 12, 2015 11:51 pm
Give it a go then :-)
Ids map here
loot
Postby tibsy » Fri Feb 13, 2015 12:31 am
loot wrote:Give it a go then :-)
will do :D
tibsy
Postby DINGLE » Fri Feb 13, 2015 1:10 am
Does anybody use this on mk6's. I'm tempted to invest in the wireless v86 version for use mainly on my own mk6 350 pickup. Just wondered how it performs before I bite the bullet
DINGLE
Postby tibsy » Sat Feb 14, 2015 1:01 pm
just been out and hooked it up.
done the the pump and pilot learn procedure`s-both successful! :D
but when i went to "module reprog"- pcm
all i get it a window telling me -
software version ids 86.00
service tool has not been updated for 46 days
no later calibration available on this system for pcm :cry:
what`s going on here then!???
tibsy
Postby loot » Sat Feb 14, 2015 1:10 pm
You have the latest calibration by the looks of it
Ids map here
loot
Ids map here
loot
Postby tibsy » Sat Feb 14, 2015 1:17 pm
hi Loot, so the "pcm" does not require update because the "pump/pilot learns" are no different(or very close) to whenever it was last done(if ever) is that right?
just wondered if the message about "service tool not updated " is preventing me going any further!
tibsy
Postby loot » Sat Feb 14, 2015 1:34 pm
Pump learns and other service functions don't require calibrations or ids updates.
Pcm update/Module installation or reprogramming does look for stored calibration and over the internet.(web lookup is a bit sketchy for me tho)
Your vcm will constantly tell you to update it but since it is a clone don't worry about it,
When you go to module reprogramming/pcm, ids will either see if your pcm number is the latest or whether there is an update, and will advise you what to do.
Stored calibrations are c81 which is late 2012 so any visits to Ford after that will update to a later calibration and your tool will say no available updates.
There's other stuff but I won't bore you lol.
:lol:
Ids map here
loot
Postby tibsy » Sat Feb 14, 2015 1:45 pm
i was thinking that the "pcm update",-that was when the "learn`s" data was sent to the pcm!
so strictly speaking, if you know you have the latest "pcm"update available already-you can ignore that part and simply do the pump/pilot learn`s
i have an awful lot to learn obviously :D
tibsy
Postby loot » Sat Feb 14, 2015 2:49 pm
Pump and pilot learn isn't relevant to pcm update but, if you do a pump learn then a pcm update, you'll need to do the pump learn again.
(Think of it like installing say windows 7 over exp, you still have to do windows update)
:o
Ids map here
loot
Postby tibsy » Sat Feb 14, 2015 6:27 pm
it is all starting to become clear, the mist is lifting! :lol:
thanks, Loot
oh,and you can throw as much boring stuff my way as you like(regarding ids). i want to be able to master most of it if not all.
then hopefully i will be able to offer my services to others.
tibsy
Postby ake » Sat Feb 14, 2015 6:35 pm
DINGLE wrote:Does anybody use this on mk6's. I'm tempted to invest in the wireless v86 version for use mainly on my own mk6 350 pickup. Just wondered how it performs before I bite the bullet
Yeah, they work on Mk 6, although on Mk 6 all you really do is read codes and program new fuel pumps ;)
Postby DINGLE » Sun Feb 15, 2015 1:49 am
Still worthy buying one then. From what I've seen they still work out cheaper than a transit compatible universal diag machine or code reader and much more useful. I need to get 2 transits plugged in ASAP. which will end up costing a good whack what could of gone towards buying my own. Unfortunately haven't got time to wait for postage
DINGLE
Postby Tango330 » Mon Feb 16, 2015 2:49 pm
Bought one on Saturday, just waiting for it to arrive :shock:
Will no doubt be back for help then Loot :lol:
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
