54plate, 2.0 duratorq wont run?
Re: 54plate, 2.0 duratorq wont run?
Postby looneyfitter » Mon Jan 24, 2011 7:35 pm
ill have a little read of them in a min, cheers sean. Found a couple of pics... Which one is mine mate? an you see the teeth when you take the atarter off?
Where is tdc? as in where you put the 14mm bit>
http://www.eurocarparts.com/ecp/c/Ford_ ... f269a&DMFW
http://www.eurocarparts.com/search/336590090/p/home
I WILL GET THIS FEcKER RUNNING!!!
looneyfitter
Postby winterheating » Mon Jan 24, 2011 8:03 pm
THe first one is the tddi one, with cutouts 10mm, the second is tdci flywheel, with 5mm tabs sticking out.
winterheating
Postby looneyfitter » Mon Jan 24, 2011 9:10 pm
can you see the cut outs from the starter hole mate? Also sent that guy a pm from the other site. He said he rang the garage for me and they said it started, ran for 5-8 secs, revved up then died. Exactly the same as me.... May be in look then. Do you think its worth the effort tho? I think that the 85 could be remapped to possibly 100-115? so the 115 could possibly be mapped to 130-135?
Still curious. whats easiest way to remove the fly on a tranny? Engone out or gearbox out?
Whats the cheapest pcm coder out there? Also tried the bay for tis but couldnt find/work out what i needed.
Good read them threads mate..... Would have made a good "How To" if you got time.
looneyfitter
Postby looneyfitter » Wed Jan 26, 2011 5:59 pm
Right took the starter off the mondeo today ... It has this fly wheel on it. It has 10mm tabs but its different to the tranny one.. Could this be my problem do you think?
http://www.eurocarparts.com/ecp/c/Ford_ ... b5df4&DMFW
Where as my tranny as you say has this one?
looneyfitter
Postby 75psT330lwb » Wed Jan 26, 2011 6:13 pm
just been to check and i have a new luk dmf which when i bought was told it was for a tdci mondeo but then on stripdown found out it wasnt the same as what was fitted! have now concluded that the flywheel is for a tddi mondeo as the transit dmf is a lot beefier in comparison, a lot heavier, and the timing lugs on a mondeo are on a sperate plate thats bolted to the dmf. so if u think about it the pcm may not even be getting a signal from crank sensor :?: unplug it then crank and she if it does the same :?: would pinpoint if it is a pickup problem :D
Custom Ecoblue
75psT330lwb
Postby looneyfitter » Wed Jan 26, 2011 9:03 pm
cheers for the reply mate. So the one you have has 10mm TABS so to speak? I have re-fitted the tranny stuff now but i will try it tomoz any ways. Out of interest if it is the case, are you selling the flywheel you have spare?
Does yours loo similar to this? MONDEO TDDI FLYWHEEL
Gareth
looneyfitter
Postby 75psT330lwb » Wed Jan 26, 2011 9:07 pm
yes mine is the same as pictured. (bit confused now)so yours is a tddi then not tdci?
Custom Ecoblue
75psT330lwb
Postby looneyfitter » Wed Jan 26, 2011 9:15 pm
my tranny is a 2.0 tddi 04 plate mate and the mondeo "donor" (took pcm,injectors and pump from) is i 2.0 tddi 115ps 51 plate.. So the 2 tddi's use different flywheels...
The guy on the other forum i posted the link to, fitted the tdci fly by mistake and got the same faults as me.
Do you have a photo of a tddi tranny fly by any chance?
looneyfitter
Postby 75psT330lwb » Wed Jan 26, 2011 9:28 pm
maybe because of the readings the pcm is getting(if any). have u tried disconnecting the crank sensor to see if it does the same?
Custom Ecoblue
75psT330lwb
Postby looneyfitter » Wed Jan 26, 2011 9:37 pm
im planning on disconnecting it tomorrow and see what happens. As said tho, its all back together now tho and running on the 85ps transit stuff... My goal is to have it running at 115ps on the mondeo stuff.
Need to find a mondeo flywheel now tho, as the one i showed you in the pic is knackered.
looneyfitter
Postby 75psT330lwb » Wed Jan 26, 2011 9:46 pm
just been thinking that the flywheel i mentioned that was heavier is for the rwd transit. both the mondeo and transit are fwd arent they so they will have the lighter one? are the crank sensors different for transit/mondeo? not sure.
Custom Ecoblue
75psT330lwb
Postby looneyfitter » Wed Jan 26, 2011 9:54 pm
crank sensors are the same on both mate.. Im now wondering if i can fit an external pickup ring to the crank pulley and making a crank sensor holder..
looneyfitter
Postby looneyfitter » Wed Jan 26, 2011 10:04 pm
Where is tdc on this pick? Is it the bit that is solid? Why is there 2 solid parts?
looneyfitter
Postby 75psT330lwb » Wed Jan 26, 2011 10:07 pm
so to sum it up the transit engine packed in and u got a donor mondeo to swap everything over? whats happened to the transit flywheel? was it the same as the one fitted now or do u not know/have it? if u did have it could u swap the ring gear from one to the other as there only riveted on? everytime u connect the mondeo pcm and wiring the engine starts then dies but runs fine on transit pcm/wiring?
Custom Ecoblue
75psT330lwb
Postby 75psT330lwb » Wed Jan 26, 2011 10:10 pm
looneyfitter wrote:Where is tdc on this pick? Is it the bit that is solid? Why is there 2 solid parts?
wasnt sure myself when i changed mine but on the tdci it only has one space(no metal) which i assume is the pickup part. think the tddi has 2 pulses whereas the tdci just 1 if ya get what i mean. puzzled with this one though as there both tddi :?
Custom Ecoblue
75psT330lwb
