DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby martinh1988 » Tue Apr 03, 2018 7:46 pm
That’s brilliant. Thank you!
martinh1988
Postby Tourneo for now » Tue Apr 03, 2018 10:09 pm
Cheers for all the info,
Rob.
Tourneo for now
Postby Rabman » Fri Apr 06, 2018 4:05 pm
Hullo there, looking for the info on van reg. BN07GWJ if anyone oot there is able to check etis that would be much appreciated
Rabman
Postby uriahdemon » Sat Apr 07, 2018 7:05 pm
Hi, I got details of my old van via this but I think I have forgotten the process. So just adding the reg which is - HG12 EEW but if I have this wrong hopefully someone can advise me.
Thanks in advance.
uriahdemon
Postby uriahdemon » Sat Apr 07, 2018 7:06 pm
Thanks very much indeed for your help. My van is HG12 EEW. Thanks in advance for your help.
uriahdemon
Postby ned » Sat Apr 07, 2018 8:45 pm
Rabman wrote:Hullo there, looking for the info on van reg. BN07GWJ if anyone oot there is able to check etis that would be much appreciated
Transit 2006-2014, 2.4L Duratorq (85kW/115PS), Frozen White
VIN Number: WF0XXXTTFX7K79810
Registration Number: BN07GWJ
First Registration Date: 31.03.2007
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 09.02.2007
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 350E Series
Engine: 2.4L Duratorq (85kW/115PS)
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With High Roof
High Door Height
With Full Partition - Steel
With Hinged Rear Loading Doors
With 256° Cargo Door Check Arms
With Magnetic Rear Door Catch
Otosan (Turkey) Plant Build
Complete Vehicle
Less Marketing Flex Prep Pack
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
European Environmental Label
With Manual Front Windows
With Clear/Light Tinted Glass
Less 2nd Row RH Side Window
With Rear Blanking Panel
Less Heated Rear Window
Less Rear Compartment Trim Panel
With Black Air Vent Knob
With Load Space Tie Down Loop
Less Rear Window Protector
With Rear Step - Centre
Less Rear View Mirror
Large Head/Short Arm Mirror
Seat Pack 22
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
With Front Towing Hook
Fleet Key
With Door Dead Locks
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rear Seat Belts
Less Passenger Air Bag
Less Float Mounting
With Spare Tyre Security Package
With Single Rear Wheels
With Standard Tread - Any Vendor
Less Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Less Rear Stabilizer Bar
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
With Sngle.L/B Dvr/Dual L/B Pass.St
Less A/C Unit - Roof Mounted
With Recirculating Heater
Fuel Water Separator Less Sensor
Less Auxiliary Heater
With MPH/KMH Speedometer
Extra Heavy Duty Battery
With Radio Pre-Equipment Pack 1
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 2
Less Voice Activated Modules
Less Column Stalk Radio Controls
With High Mounted Stop Lamp
Less Battery Cut Off Relay
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Sat Apr 07, 2018 8:47 pm
uriahdemon wrote:Hi, I got details of my old van via this but I think I have forgotten the process. So just adding the reg which is - HG12 EEW but if I have this wrong hopefully someone can advise me.
Thanks in advance.
Transit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Frozen White
VIN Number: WF0XXXTTFXCB56408
Registration Number: HG12EEW
First Registration Date: 26.04.2012
Primary Features
Build Date: 25.01.2012
Series: 1.7-350L Series
Engine: 2.2L CR TC I4 DSL 125 PS
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.93/3.450
Emission: Stage V LDT3 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Minor Features
With High Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
With Kerbside Side Load Doors
With Diesel Particulate Filter
Less Back Panel Bulkhead Grille
Brake System - Regenerative
With Full Partition
With 180° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Less Special Equipment Package
Less Sales Badge
Less Trim Pack
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Less Paint Package
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
Less Rear Side/Back Security Glass
With Heated Windscreen
Less Overhead Console
With Header Mounted Package Tray
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
Less Exterior Body Mouldings
Manual Dual Mirror-Manual Fold Back
Less Seat Construction
Less Rear Underseat Stowage Bin
Less Rear Seat Recliner
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
Less Removable 2nd Row Seat
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Zonal Opposite Door Relocking
Less Configurable Unlocking
With Power Lock Group
Two Step Door Unlock System
Less Rain Sensor - Front W/Wiper
Less Sun Roof
Less Rear Sunroof
Self Colour Rear Bumper End Caps
Mid Grey Front Bumper
With Grey Plastic Rear Bumper
Less Rear Bumper Under Run
Less Bumper Underrun - Front
With Driver Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
5.5 X 16" Steel Wheel
215/75R 16C BSW Tyres
With Wheel Hub Cap
Non Locking Lug Nuts
Diesel Fuel Cooler
Standard Electric Starter Motor
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
With Down Turned Exhaust Exit
Less Transfer Case
Less Skid Plates
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
Less Tachograph
Less Tripminder Assy
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
With Daytime Running Lamps
Less Front Fog Lamps
Less Roof Marker/Clearance Light
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Front Headlamp Levelling
Less Headlamp Control
Less Instrument Panel Dimmer Switch
Less Wiring Harness
ned
Postby steve cooper » Sun Apr 08, 2018 8:19 am
Hi. I’m looking for the details on ek61uhg.
Thanks very much.
steve cooper
Postby ned » Sun Apr 08, 2018 8:54 am
steve cooper wrote:Hi. I’m looking for the details on ek61uhg.
Thanks very much.
Transit 2006-2014, 2.4L Duratorq-TDCi (100PS) - Puma, Frozen White
VIN Number: WF0XXXTTFXBJ41937
Registration Number: EK61UHG
First Registration Date: 26.10.2011
Primary Features
Build Date: 17.09.2011
Engine: 2.4L Duratorq-TDCi (100PS) - Puma
Drive: RHD RWD
Axle Ratio: 3.73
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Minor Features
With Medium Roof
With Rear Mudflaps
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
Less Diesel Particulate Filter
Less Brake System-Regenerative
Less Liftgate
With Aux I/P Console - 2 Din Horznt
Less Sales Badge
Less Trim Pack
Marketing Level 3
Less Dress Up RSO
With Tool Kit
Less Heated Windscreen
Less Running Boards
Less Roof Rack
Less Rear Step
Less Fleet Key
Less Sun Roof
Less Rear Sunroof
With Driver Air Bag
Less Float Mounting
70MPH Engine Governor
Diesel Fuel Cooler
Solid Flywheel
Less Transfer Case
Less Skid Plates
Less Heater
With Digital Tachograph
With Tachometer
Less Bluetooth
Ice Feature Pack 5
Less Telephone
Less Microphone
Electrical Outlet
Less Camera
Less Wheel Pack
Less Aero Pack
Less Daytime Running Lamps
Less Wiring Harness
ned
Thanks very much.
Primary Features
Drive: RHD RWD
Axle Ratio: 3.73
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Minor Features
With Medium Roof
With Rear Mudflaps
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
Less Liftgate
Less Sales Badge
Less Trim Pack
Marketing Level 3
Less Dress Up RSO
With Tool Kit
Less Running Boards
Less Roof Rack
Less Rear Step
Less Fleet Key
Less Sun Roof
Less Rear Sunroof
With Driver Air Bag
Less Float Mounting
Diesel Fuel Cooler
Solid Flywheel
Less Transfer Case
Less Skid Plates
Less Heater
With Tachometer
Less Bluetooth
Ice Feature Pack 5
Less Telephone
Less Microphone
Electrical Outlet
Less Camera
Less Wheel Pack
Less Aero Pack
Less Wiring Harness
ned
Postby steve cooper » Sun Apr 08, 2018 11:35 am
Thanks.
I never knew they made a 2.4 100ps 6 speed with a 3.7 diff
steve cooper
Postby Rabman » Sun Apr 08, 2018 1:53 pm
Cheers for the info ned
Rabman
Postby Rosso » Sun Apr 08, 2018 4:04 pm
Can you check SA11FFW please? Can’t get full spec via iPhone!
Cheers
Rosso
Postby paulwps » Sun Apr 08, 2018 6:26 pm
Hi , can anyone tell me how many splines on my gearbox please,
I am having problems getting a re-conditioned one
It says on the label. 3C1R 7002 EB
And are there any other compatible boxes
The vin is WF0AXXTTFA5D34639. X1
I think i have found one but they're asking for the variant ?
Reg ,NA06SYE
Thanks in advance
Paul
paulwps
Postby ned » Sun Apr 08, 2018 7:22 pm
Rosso wrote:Can you check SA11FFW please? Can’t get full spec via iPhone!
Cheers
Outstanding Field Service Actions
2C489 - TRANSIT - REAR BRAKE PIPE TO AXLE SECURING BOLT
VIN Number: WF0XXXTTFXBL40810
Registration Number: SA11FFW
First Registration Date: 31.05.2011
Primary Features
Build Date: 18.05.2011
Series: 350M Series
Drive: RHD RWD
Axle Ratio: 3.73
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Minor Features
With Medium Roof
With Rear Mudflaps
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
Less Liftgate
Less Sales Badge
Less Trim Pack
Marketing Level 3
Less Dress Up RSO
With Tool Kit
Less Running Boards
Less Roof Rack
Less Rear Step
Less Fleet Key
Less Sun Roof
Less Rear Sunroof
With Driver Air Bag
Less Float Mounting
Diesel Fuel Cooler
Dual Mass Flywheel
Less Transfer Case
Less Skid Plates
Less Heater
With Tachometer
Less Bluetooth
Ice Feature Pack 5
Less Telephone
Less Microphone
Electrical Outlet
Less Camera
Less Wheel Pack
Less Aero Pack
Less Wiring Harness
ned
