Mk7 denso injectors
Re: Mk7 denso injectors
Postby v8dave » Sat Feb 13, 2016 4:20 pm
Could be the fuel ?
I recently put a tank of "premium" diesel in because the price had dropped so low, wish I hadn't - it ran rough and the consumption was awful.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby loot » Sat Feb 13, 2016 4:42 pm
Possibly i guess, but I'm using the same fuel as i have for a long time :-)
Needs investigating :-(
Ids map here
loot
Postby knobby1 » Sun Feb 14, 2016 9:11 pm
Loot...I wonder if your SCV is a bit off, I've pulled my original one apart not long ago and found a few small "score" marks in the bore and on the piston itself...The piston should fall in and out under it's own weight, mine didn't...I gave them a good clean with alcohol and then a wee polish with some very fine "5000" grade polishing paper and she came good...Might pay to have a look at yours and do the same thing...I'd do the learns again after though, you'll have changed it's characteristics a wee bit.
There's a small circlip holding the piston/valve in, and a spring behind the the valve. Check the metering edges of the valve and the outer metering ports for nicks or damage etc, you may need a magnifying glass to do so though...I'm thinking any amount of "hangup" here will cause hunting issues.
Postby loot » Sun Feb 14, 2016 10:12 pm
This 1?
Takes me back Lol :-)
Might leave it if they're only good for a year and a half Lol.
Bloody Ford
Bloody Denso
These should be no more than 25 pounds :? :x
Ids map here
loot
Postby knobby1 » Sun Feb 14, 2016 11:42 pm
That's the one....have a good look at the metering slots on each side of the main housing too....!
Postby loot » Sat Dec 17, 2016 11:40 am
Has anyone used data logger in ids to turn off and on individual injectors to try and eliminate noises?
Ids map here
loot
Postby Blue_Courier » Mon Feb 05, 2018 2:47 pm
good afternoon transit lovers
I need your help.
I have transit mk7 2.2 PGFA 140hp Euro 4, System injection/pump denso, but the engine broke.
I bought a motor mk8 CVR5 155hp, System Injection/pump siemens.
Is it possible to install in my mk7, the CVR5 with injection and pump siemens?
Or i have changed to the System injection/pump denso?
Regards from portugal
Blue_Courier
