NEW MOT RULES REGARDING DPF, E/C SYSTEMS, ENGINE MIL LIGHT
Re: NEW MOT RULES REGARDING DPF, E/C SYSTEMS, ENGINE MIL LIG
Postby loot » Tue Aug 14, 2018 10:58 pm
Hi Paul, just to clarify as I'm getting on a bit but it is saying that if a vehicle was a class 7(I presume anyway) but got changed to m1 living van (day van/camper) but doesn't show it on the logbook or chassis plate then where it was mot'd as an m1 class 4, it can no longer be class 4 if there is no evidence that it qualified as class 4 m1.
If someone converted it to m1 class 4 then they would have proof wouldn't they? And if they don't then how would or could they have got it mot'd as class 4 anyway?
Ids map here
loot
Postby paul2012 » Wed Aug 15, 2018 4:08 am
loot wrote:Hi Paul, just to clarify as I'm getting on a bit but it is saying that if a vehicle was a class 7(I presume anyway) but got changed to m1 living van (day van/camper) but doesn't show it on the logbook or chassis plate then where it was mot'd as an m1 class 4, it can no longer be class 4 if there is no evidence that it qualified as class 4 m1.
Correct. A class 7 vehicle that's been converted to a living van (day van/camper) but has vehicle catagory N1 on V5c. - It will still be tested as class 7.
loot wrote:If someone converted it to m1 class 4 then they would have proof wouldn't they? And if they don't then how would or could they have got it mot'd as class 4 anyway?
Prior to May 20th. it was down to the vehicle presenter to confirm if vehicle has the capacity to carry goods. If presenter said no to goods. Tester could have easily tested vehicle as a motor home. (class 4).
Quite a few living vans have been successfully registered as catagory M1 on V5c - They will still be tested as class 4.
With the the latest amendment. For a living van to be tested as class 4. It has to be confirmed that vehicles type approval is M1.
Easily done by presenter providing V5c as proof.
It also gives a clear definition between a living van & Motor caravan.
A living van is a vehicle used for
living accommodation by one or more persons and which is also used for the carriage
of goods or burden which are not needed by such one or more persons for the
purpose of their residence in the vehicle. Living vans are classed as goods vehicles & subjected to speed limits set for goods vehicles.
A motor caravan is a motor vehicle which is constructed or
adapted for the carriage of passengers and their effects and which contains, as
permanently installed equipment, the facilities which are reasonably necessary for
enabling the vehicle to provide mobile living accommodation.
Motor caravans are not classed as goods vehicles & subjected to same speed limits set for cars providing unladen weight is no more than 3.05 tonnes maximum
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby tranviper » Mon Aug 20, 2018 12:14 am
karl wrote:
but yet their is plant out their over 30 years old keeping the economy going. HENCE the making of the new hs 2 etc. but hang on we will send all are polluting diesels to 3rd world countries :shock: :roll:,
and know their is the electric bollocks. its OK we will go to the 3rd would countries, where we can dig and mine a we can :oops: using the old machines we exported :twisted: so us a country get to are targets for low emissions
Just dumping old junk smokers in Africa is not that easy
Not quite, where I am they test for emissions on ALL commercial vehicles yearly, they will randomly select private vehicles for a roadside check and if it fails we just slip a couple of notes as a goodwill gesture to look after his barefooted kids, not I have ever done so as the occasion never arosem was once tested for smoke on the side and the tester couldn't believe my van didn't smoke as this is possibly thee only MK6 in South Africa...long story why and how, another day........
tranviper
Location: Durban, South Africa...where life is chilled out, lots of sun and surf
Postby axam102 » Sat Aug 25, 2018 10:16 pm
Having a gander through the new rules and being subject to them a couple of times for the latest test it isn't that much different. just a few new checks. it seems that the dodgy garage quick quid is brake fluid contamination... £60 quid labor plus fluid... seemed pretty pissed when I said no I can do that dont touch it. I didn't change it and went back in and passed with nothing more than writing 2019 on the brake fluid cap...
axam102
Postby paul2012 » Fri Sep 21, 2018 5:08 pm
From Saturday 1 September 2018, electric goods vehicles with a GVW not exceeding 3500kg & 1st used on or after 1 March 2015.
Will NO longer be exempt from MOT test. :!:
New updates to MOT from Thursday 13 September 2018
1.1.12 Flexible brake hoses
b (ii). A flexible brake hose excessively damaged, deteriorated, chafed, twisted or stretched *MAJOR*
f (i). A brake hose ferrule excessively corroded *MAJOR*
f (ii). A brake hose ferrule excessively corroded and likely to fail *DANGEROUS*
1.1.13 Brake linings and pads
a (i). Brake lining or pad worn down to wear indicator *MAJOR*
1.8 Brake fluid
Hydraulic brake fluid level checks are confined to transparent reservoirs, reservoir caps shouldn’t be removed.
a. Brake fluid contaminated *Major*
4.2.3 Compliance with requirements - Front and rear position lamps, daytime running lamps and end-outline
c. A position lamp adversely affected by the operation of any other lamp *MAJOR*
c. A outline marker lamp adversely affected by the operation of any other lamp *MAJOR*
4.3.3 Compliance with requirements - Stop lamps
b. A stop lamp adversely affected by the operation of another lamp *MAJOR*
4.4.3 Compliance with requirements - Direction indicators and hazard warning lamps
A direction indicator adversely affected by the operation of another lamp *MAJOR*
4.5.4 Compliance with requirements - Front and rear fog lamps
a. Front or rear fog lamp emitted colour or position not in accordance with the requirements *MAJOR*
b. A rear fog lamp adversely affected by the operation of any other lamp *MAJOR*
4.6.2 Compliance with requirements - Reversing lamps
a. Reversing lamp emitted colour or position not in accordance with the requirements *MAJOR*
4.7.1 Presence, condition and operation - Rear registration plate lamps
b (i). A rear registration plate lamp or light source missing or inoperative in the case of multiple lamps or light sources *MINOR*
b (ii). A rear registration plate lamp or light source missing or inoperative in the case of a single lamp or all lamps *MAJOR*
5.2.3 Tyres
j. A tyre valve seriously damaged or misaligned likely to cause sudden deflation of the tyre *DANGEROUS*
k. A tyre incorrectly seated on the wheel rim *MAJOR*
5.3.2 Shock absorbers
c. A shock absorber bush excessively worn *MAJOR*
5.3.3 Suspension arms, rods, struts, sub-frames, anti-roll bars etc
c (ii). A suspension component modified so that the suspension is inoperative or likely to foul other components *DANGEROUS*
6.1.2 Exhaust system
a. Exhaust system has a major leak or is insecure *MAJOR*
7.1.1 Seat belt security
a (i). The strength or continuity of the load bearing structure within 30cm of any seat belt anchorage (a ‘prescribed area’) is significantly reduced or inadequately repaired *MAJOR*
7.7 Audible warning (horn)
c. Audible warning sound not in accordance with requirements *MAJOR*
8.2.2.2 Opacity
g. Engine MIL inoperative or indicating a malfunction *MAJOR*
paul2012
Postby karl » Fri Sep 21, 2018 6:50 pm
they changed this last week or the week and took it of as many vehicles have electronic indicators and can just be a broken wire like the transits :shock:
karl
Tranny Lover!!!
Postby Jim Archer » Sun Oct 14, 2018 3:05 pm
Pads themselves have a minimum wear mark that the tester is supposed to visually check. Most of the lazy feckers have been just looking at the light on the dash, and passing well worn pads, or failing those still in spec but with damaged wiring causing the warning light to illuminate.
I understand it is being reworded suitably.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby paul2012 » Tue Oct 23, 2018 5:36 pm
Jim Archer wrote:Pads themselves have a minimum wear mark that the tester is supposed to visually check. Most of the lazy feckers have been just looking at the light on the dash, and passing well worn pads, or failing those still in spec but with damaged wiring causing the warning light to illuminate.
Jim
Yes. All brake pads have a wear indicators. Just like these front pads for Mondeo mk3 / Jag X-Type.
Although worn down 50% - Noted down as a "MINOR" defect on MOT - :?
paul2012
Postby ned » Tue Oct 23, 2018 6:03 pm
Is this to stop that stupid stretched euro look on the side walls?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby andz327 » Mon Nov 05, 2018 12:29 am
What about mk7 tranny thats been turned into old school 2LTR TDDI and all the mods and sods kinda vehicles man this is fuktable......tenner in the ashtray wilk be a score noo
ANDZ
andz327
Postby paul2012 » Wed Nov 21, 2018 10:43 pm
An increase of 448% in the number of diesel vans that failed MOT emissions test (Smoke Test). Since new MOT rules were introduced in May 2018.
https://www.gov.uk/government/news/new- ... Bb9iQf0cbA
paul2012
Postby bigjohnthomas » Thu Nov 22, 2018 12:45 am
Vans?
I see no vans
bigjohnthomas
Postby ned » Thu Nov 22, 2018 1:03 am
Them dirty diesels eh,
Since 20 May 2018, a total of 238,971 diesel cars and 505,721 petrol cars have failed the new emissions test.
Seems petrol engines are still worse polluters :lol: :lol:
ned
Postby paul2012 » Thu Nov 22, 2018 6:36 pm
bigjohnthomas wrote:Vans?
I see no vans
Here you go..... :wink:
paul2012
Postby paul2012 » Tue Jan 22, 2019 12:20 am
MORE new MOT rules will be introduced later this year (2019) :idea:
Vehicles will be checked at MOT for Outstanding vehicle recalls - Outstanding recalls will result in MOT refusal :!:
More updates to follow.....
paul2012
