mk6 steering wheel boss
Postby glenandemm » Mon Nov 13, 2006 9:56 pm
does anyone know which steering wheel boss from anouther car will fit a mk6 transit?, quite fancy a momo, not bothered about airbag
glenandemm
Postby glenandemm » Fri Nov 17, 2006 1:24 pm
i take it no ones fitting any aftermarket steering wheels to these yet :? :?:
glenandemm
Postby rover » Fri Nov 17, 2006 1:37 pm
If you dont have an airbag you will have to have the electronics sorted otherwise the light will show and it will fail an M.O.T
Rover.
rover
Postby glenandemm » Fri Nov 17, 2006 9:52 pm
not if you take the bulb out :D ,anyway i could always swap back for mot ,i really fancy the feel of a momo as im drifting my bus sideways at 2.00 in the morning taxi'ing, so come on somone tell me which boss fits a mk6 :?:
glenandemm
Postby MrMPuk » Fri Nov 17, 2006 10:48 pm
Taking the bulb out isn't an option :wink:
Postby motorwise » Fri Nov 17, 2006 11:20 pm
the airbag is not part of the MOT test
http://www.motorwise.net
motorwise
Postby rover » Fri Nov 17, 2006 11:47 pm
The air bag itslef isnt but the light must go out!
Rover.
rover
Postby motorwise » Fri Nov 17, 2006 11:59 pm
rover wrote:The air bag itslef isnt but the light must go out!
Rover.
you're thinking of the ABS - no part of the airbag system is a testable item
motorwise
Postby glenandemm » Sat Nov 18, 2006 12:25 am
why isnt taking the bulb out an option are they not backlit by bulbs in mt minibus......sorry passengervan :lol:
glenandemm
Postby rover » Sat Nov 18, 2006 9:33 am
Rover.
No I'm not!
If the air-bag light is flashing the tester can fail it on 'general vehicle condition' items, most wont but you only need an overzealous tester and you have problems :(
Rover.
rover
Postby motorwise » Sat Nov 18, 2006 9:03 pm
I've been a VOSA nominated tester since 1993 and at no time has any airbag component been subject to test - a loose exception could be if someone presented a car for test with a steering wheel in which the air bag had already been deployed leaving sharp edges on the plastic cover
reason for rejection would be something like "steering wheel in a condition likely to injure the driver" - anything else on the airbag can only be advised (and thats only if the tester feels like it - he has no obligation to do so)
here's a link to the testers manual - it's simple if it's not in here - it's not subject to test
http://www.motuk.co.uk/manual/contents.htm
motorwise
Postby rover » Sun Nov 19, 2006 2:05 pm
I already have a current testers manual and all the updates when they come out, we'll just have to agree to differ on this one mate!
Rover.
rover
Postby motorwise » Sun Nov 19, 2006 8:20 pm
rover wrote:I already have a current testers manual and all the updates when they come out, we'll just have to agree to differ on this one mate!
Rover.
just an idea - why don't you read it! :wink:
motorwise
Postby Nighthawk » Sun Nov 19, 2006 11:33 pm
rover, out of interest what would you fail it as?
I've held a class 4 and 7 ticket for a number of years and never come across a valid reason for rejection for an SRS light on.
As the system isn't part of the test, non of it's components can be held as reason for failure.
As mentioned earlier, a deployed airbag could lead to failure of the test as part of steering controls.
If a tester notices any warning lamp outside of the test requirements, it should be noted as an advisory.
Transit.........Job done
Nighthawk
so then
Postby jamiedq » Sun Nov 26, 2006 12:55 pm
so does anyone know about fitting aftermarket wheel boss for the mk6. i wouldn't mind getting rid of my stock whel too
jamiedq
