andz327 wrote:Runs just the same mate straight swap electronic vnt turbskie for electronic vnt turbskiened wrote:andz327 wrote:Nice
If I'm passing in next day or so I'll drop off the Milwaukee for you mate and catch it on way back up
Is this any use to you
ANDZ
I don't want to put you out in any way, it should only takes 10 minutes or so to undo the manifold nuts going to order the new one tomorrow evening when I get paid, the kit is new turbo, manifold, gaskets, nuts, boots ect all for £190
Did you use the old oil supply pipe, looks a bit rusty, how's your van running with the 140 turbo fitted, was the 130 turbo a variable vane turbo?
That pic is from a vacum actuated turbo that was on the engine that i swapped into Bettsie but 2.2 only has 3 bolts holes which sounds much diff from yours
ANDZ
Wish mine was a 3 bolt jobbie, be much easier, the snail on this van is built into the exhaust manifold,
£190 for that lot remanufactured obviously.
