What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby Altransit » Mon Jan 24, 2022 8:55 pm
ned wrote:
DG-Unit wrote:I'll check my cabin filter hasn't rusted too much. Could be an MOT fail.
If you can find it, Ford had the grand idea of putting the turbo heat shield over it :roll: :lol: :lol:
I'm pretty sure that the later Mk6's didn't have a pollen filter, my 2004 certainly didn't :)
Postby DG-Unit » Tue Jan 25, 2022 11:49 am
Doesn’t matter now. Even if I do find it I can’t afford to replace it now: Resident parking permit last year £130… this year £195 :oops: For that money we get streets with bike lanes designed using crayons, parking spaces removed on each corner to make way for temporary taxi ranks (double yellows to the rest of us), EV charging spaces for the rich, Southern Gas digging up the road every 6 months and twice a year having your whole street closed off for youtubers to film some influence likes.
2004 Transit SWB 85 T260
DG-Unit
Postby Altransit » Tue Jan 25, 2022 12:15 pm
DG-Unit wrote:For that money we get streets with bike lanes designed using crayons, parking spaces removed on each corner to make way for temporary taxi ranks (double yellows to the rest of us), EV charging spaces for the rich, Southern Gas digging up the road every 6 months and twice a year having your whole street closed off for youtubers to film some influence likes.
Sounds idyllic :roll: :mrgreen: :(
Postby Brettbear63 » Tue Jan 25, 2022 12:19 pm
Today had a new fuel filter and a M.A.F sensor fitted .
Brettbear63
Postby Nordic Blue » Tue Jan 25, 2022 1:43 pm
Altransit wrote:I'm pretty sure that the later Mk6's didn't have a pollen filter, my 2004 certainly didn't :)
I got a local mobile garage to service my 2005 last year and they turned up with a pollen filter, but he said it didn't have one.
He was a bit confused as I assume he had done a registration look up before he came and must have been told it had one.
Thanks Al, that makes a bit more sense!
2009 Renault Trafic Sport Crew Cab
Vans I have also owned:
1982 MK 2 SWB Transit
1992 Fiat Ducato
1993 MK 4 SWB Transit
2005 MK 6 SWB T280 Transit
Nordic Blue
Postby ned » Tue Jan 25, 2022 1:47 pm
Either that or he couldn’t find it, you have to remove the metal heat shield under the windscreen then look up if it has one it’ll be there behind a plastic door, but as said they stopped putting them in.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby firststrike » Wed Jan 26, 2022 12:51 am
Replaced the rear hub oil seal and gasket along with brake pads which had become saturated in rear axle oil.
firststrike
Postby Brettbear63 » Thu Jan 27, 2022 8:28 am
Brettbear63 wrote:Today had a new fuel filter and a M.A.F sensor fitted .
I also fitted the missing Cabin filter , the old Fuel filter was full of gunge , van now actually starts and ticks over . :D
Brettbear63
Postby loot » Thu Jan 27, 2022 11:42 pm
Oil filter and oil is a must, air filter if it is bone dry and nearly white /yellow then it may do with a blow out, fuel filter if it looks old ams rusty or chugs.
Pollen filter well, I wouldn't put it as a requirement really.
On the custom there's a pollen filter or a smelly air filter option depending on whether you have hay fever or an oversion to stinky air.
Won't bother your van either way I'm sure.
:mrgreen:
Ids map here
loot
Postby Havoc99 » Fri Jan 28, 2022 2:05 pm
New windscreen fitted by national windscreens Gloucester.
Good price, excellent customer service, hassle free.
Havoc99
Postby ray1965 » Fri Jan 28, 2022 8:31 pm
Havoc99 wrote:New windscreen fitted by national windscreens Gloucester.
funnily enough, I'm having a new screen fitted tomorrow, only got a small chip, but the main bulk of the heated elements don't work anymore, and i also want the screen with the bit that holds a rear view mirror
£230 supplied and fitted, and no, my insurance doesn't cover screens, not sure how that compares to others as its just a fitter I've always used
ray1965
Postby 100T300L » Sun Jan 30, 2022 8:47 pm
Cabin filter on MK6 was a dealer retro fit kit. Very rare to see now. ~20 years ago I changed only few filters.
100T300L
Postby Airthies » Thu Feb 03, 2022 11:23 pm
Last night a tooth came adrift from the pinion gear in the diff, extracted said rogue tooth at the side of the road, too other cracked teeth ready to follow suit. Tried to see if they'd come out but despite being loose the seamed retained, so buttoned it up and headed for home.
Today I dragged out original diff from van that's been stored since swapping everything from the first van as it's a higher ratio than the front I'm using.
I've since found that the ranger also has a very similar ratio to this one so instead of trying to find a good used 3.73 rear, I've just bought a complete ranger diff and drive shafts with 3.5 ratio for less than folk are trying to sell rear axles
So prepped the axle, removed hubs as I'm swapping them for the ones I've just put disks on, had issues with one hub nut picking up on the threads but having two axles the other one came off ok so we're all good, cleaned up threads and replaced hub seals. Should of put new hub bearings in I suppose but these seam ok for now, maybe a job for another day.
Anyway best get on and hopefully finish before midnight
Seng frod gay Armor 8 Prolapse pulsing Crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby DG-Unit » Mon Feb 07, 2022 11:57 am
First day allowed outside after 12 days of quarantine and the van passed it’s MOT.
DG-Unit
Postby Scooby doo » Sat Feb 12, 2022 10:45 am
Gave her her 1st bath in a year, despite todays lil trip not going to plan, least she’s gleaming again..
Feels like the clutch is failing again, she’s holding back when you floor it, revs go up but speed doesn’t, she revs sweetly with clutch pressed in
Scooby doo
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot], metalworker0
