What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby mariuzzu74 » Sat May 29, 2021 6:33 pm
Hi,
on my 2.4 TDCI 85 Kw RWD, yesterday and today I managed to replace the rear differential oil and above all the front brake discs and pads!!!
It was a hard job but in the end I did it!
I also changed the brake fluid; I'm tired but I enjoyed it ...
Sorry I didn't take pictures!
Ad maiora...
mariuzzu74
Postby andz327 » Sat May 29, 2021 7:29 pm
tilly wrote:
Cut back to good metal they said....
Sent from my SM-G975F using Tapatalk
andz327
Postby andz327 » Sat May 29, 2021 7:47 pm
ned wrote:My manly van has been being made more manly today, ok so it’s had new wheel bearing, couldn’t do the cv joint as it doesn’t bloody fit, again :roll: is there 2 sizes of driveshafts used on these mk6’s, a girly tddi one and a beefy manly tdci one?
Bearing out in 15 minutes,
How to press a new bearing one without a press, use the new cv joint you bought a few years ago that doesn’t fit the van
Snapped the drop link bolt :oops:
But was inspired by engineering types (he spoke to me from the other side)
Threaded bar and some nuts looks safe to me.
Also took Mr Airthies advice and put some washer in the sld middle roller, I can almost open the door fully now, almost as it could do with 1 more washer but the bolt isn’t long enough, bloody ford.
Don't know about mk6 but the mk7 140 fwd has .....now cam yer self doon girls....... a thicker shaft ,
Mr N I've a good 140 cv joint if you want to try that on ??
andz327
Postby Scooby doo » Sun May 30, 2021 8:43 am
I’m curious to know if Ned could take a thicker shaft..and pictures will always say a thousand words…
Don’t forget to use plenty of lube to make sure that shaft slides in nicely :lol:
Scooby doo
Postby ned » Sun May 30, 2021 9:05 am
It makes sense these higher power vans have a manly shaft,think mine is a 34 or 36 spline shaft (not easy to count) is the mk7 cv the same as the mk6 that is the question,
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Sun May 30, 2021 9:08 am
Lube is no good if the shaft is too big :shock: a shoe horn may help though :wink: :lol: :lol: :lol:
ned
Postby andz327 » Tue Jun 01, 2021 1:13 am
ned wrote:
Scooby doo wrote:
andz327 wrote:[quote="ned"]My manly van has been being made more manly today, ok so it’s had new wheel bearing, couldn’t do the cv joint as it doesn’t bloody fit, again :roll: is there 2 sizes of driveshafts used on these mk6’s, a girly tddi one and a beefy manly tdci one?
Lube is no good if the shaft is too big :shock: a shoe horn may help though :wink: [/quote]Good question Nedo but your welcome to try and I'll drop it off when i pick up Airthies ramadans
andz327
Postby Johnnyboy11888 » Tue Jun 01, 2021 9:14 am
Sent van to local garage at 7 a.m. and by 8 a.m. it had passed its MOT!!!
PS. After lots of ABS heartache.
Johnnyboy11888
Postby DG-Unit » Tue Jun 01, 2021 10:08 am
Johnnyboy11888 wrote:Sent van to local garage at 7 a.m. and by 8 a.m. it had passed its MOT!!!
I skim read this and thought it was the shortest Mk6/7 MOT story ever posted. It’s a good feeling though! Congrats :lol:
2004 Transit SWB 85 T260
DG-Unit
Postby ned » Tue Jun 01, 2021 8:39 pm
andz327 wrote:
ned wrote:
Scooby doo"quote="andz327"uote="ned wrote:My manly van has been being made more manly today, ok so it’s had new wheel bearing, couldn’t do the cv joint as it doesn’t bloody fit, again :roll: is there 2 sizes of driveshafts used on these mk6’s, a girly tddi one and a beefy manly tdci one?
Sent from my SM-G975F using Tapatalk[/quote]
Aye it might be worth seeing if it fit, if it does I’ll know which one to order, let us know when you plan on getting the Ramadams and I’ll leave them under the bush at the front in my house
ned
Postby dirtydog » Tue Jun 01, 2021 10:54 pm
Mot booked for the blue one tomorrow
Trying to find the right repair panel for the camper, drivers side inner sill from b pillar back. Then I can get that welded up and in for its mot
Then picking up the latest addition to the collection on Saturday
dirtydog
Postby dirtydog » Wed Jun 02, 2021 10:34 am
Well the morning is not quite going to plan, went out to get some diesel in the blue one. Got to the end of the road, hit the brakes and was ok then nothing.
Burst a brake line and of course I’ve not got time to repair it before the mot :roll: :roll:
dirtydog
Postby blue estate » Wed Jun 02, 2021 11:22 am
dirtydog wrote:Well the morning is not quite going to plan, went out to get some diesel in the blue one. Got to the end of the road, hit the brakes and was ok then nothing.
Sods law :evil:
72plt MG 5 ev estate Battery car
blue estate
Postby Johnnyboy11888 » Wed Jun 02, 2021 12:00 pm
I would be happy to add some of my woes and learnings. That said this forum had some great snippets of information on the ABS faults to help me along. I did end up changing an ABS module out but that wasn't the fault.
As to changing out front lowering ball joints I am sure there was a better way to do it. Oh, one of the CV boots dropped off during test causing a right mess.
Out through the other side now!
Johnnyboy11888
Postby ned » Wed Jun 02, 2021 7:48 pm
Depends on how you changed the lower ball joint to whether there’s a better way of doing it :wink:
ned
Users browsing this forum: Bing [Bot], Google Adsense [Bot], KayMart
