What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Sat Nov 10, 2018 1:52 pm
Tango330 wrote:Seems to be goading me the Tango van, yesterday it gave me the clutch pedal stuck down routine :roll: Fortunately the pulling it back up with the toe end worked, but maybe the master cylinder wants replacing :?
Get the pedal with your fingers and see how much free up down play there is, the plunger hole when new is a circle but mine was oval about 10mm so I could lift the pedal maybe an inch in total :shock: I thought that was normal too :lol:
Ids map here
loot
Postby Tango330 » Sat Nov 10, 2018 2:50 pm
Is the cylinder a bugger to get at Mate? Last one I did was my old Focus estate, and that was a nightmare :?
Will try the pedal and see.....
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby loot » Sat Nov 10, 2018 4:44 pm
I will say it is more annoying than difficult, I probably spent 1-2 hours including bleeding etc. I vaguely recall the job but do recall swearing a lot.
Bloody effing Ford :D
Ids map here
loot
Postby bambi mk 1 » Sat Nov 10, 2018 8:00 pm
loot wrote:
Tango330 wrote:
loot wrote:Get the pedal with your fingers and see how much free up down play there is, the plunger hole when new is a circle but mine was oval about 10mm so I could lift the pedal maybe an inch in total :shock: I thought that was normal too :lol:
Take the throttle pedal out to make it easier :idea: Be careful you dont loose the little olive on the steel pipe when removing it from the cyl.You may find it easier to loosen off the nuts on the pedal box to get the cyl back in the slots :idea:
bambi mk 1
Postby loot » Sat Nov 10, 2018 8:27 pm
bambi mk 1 wrote:[qote="loot"]
Take the throttle pedal out to make it easier :idea: Be careful you dont loose the little olive on the steel pipe when removing it from the cyl.You may find it easier to loosen off the nuts on the pedal box to get the cyl back in the slots :idea:[/quote]
That'll be the source of most of the swear words :lol:
Ids map here
loot
Postby Altransit » Sat Nov 10, 2018 10:04 pm
I changed the oil and filter :shock: 8) It was only changed about 3k miles ago but I thought it needed it :D
The old oil was blacker than the storm clouds that were gathering overhead as I was doing it, but I just managed to put the last tool away, and shut the garage door, just as the first drops came down. 30 seconds after I got back in the house, the Monsoon started :shock: :P
Postby Airthies » Sat Nov 10, 2018 10:08 pm
Rattled a few more filings off reverse gear....
Got the chance of a set of ramps next week so I need to get my finger out sorting the last bits n bobs before I put the van off the road for a few days.
Where's best for clutch cyl pipe & power steering pipes?
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ned » Sun Nov 11, 2018 1:47 pm
Not sure about this,
At least the tyres don't pertude the arches,
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Tango330 » Sun Nov 11, 2018 4:02 pm
ned wrote:Not sure about this,
Hmmm, picture from further away might give a better idea, but from them it looks OK to me mate, once you get it fitted and use your spraying talents on it :D
Looks like I'm going to bite thee bullet and get my Mate down the garage to do my master cylinder :( I don't have any other transport till I get the Focus sorted, and I just can't afford to have the van off the road for a couple of days if something goes wrong while I'm doing it :?
T330 RWD now sold
Tango330
Postby Airthies » Sun Nov 11, 2018 5:03 pm
Let the Mrs take my van as I needed hers to take the eldest and some of his mates karting for hi pals 11th birthday.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ned » Sun Nov 11, 2018 8:28 pm
I'm not sure I like it tbh so I'm just going to use Mr Aithies rubber for now just to hlget through the MOT then maybe fab the arches with glass fibre (using the connect ones) so they fit better.
I know what you mean about having the van off the road, I still haven't done the CV joint.
ned
Postby RustWidow » Sun Nov 11, 2018 10:51 pm
Oh don’t mention cv joints :( one of mine is not good lol
RustWidow
Postby ned » Sun Nov 11, 2018 11:11 pm
RustWidow wrote:Oh don’t mention cv joints :( one of mine is not good lol
Bloody pain aren't they, I paid £25 for the new one but its been sat on the dash for a while now, might get the garage to change it, at least you have a mutley to do yours :wink:
ned
Postby Airthies » Thu Nov 15, 2018 11:19 pm
Busy day on the van got to have a look at the underside without being on the ground flat on my back for a change
Progress, with a slight panick, but progress nun the less. Image
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ned » Fri Nov 16, 2018 5:04 pm
Got my MOT but got a few advisory's :( at least it passed :D
ned
