ned wrote:Well that was surprisingly easy, fitted the led 3rd brake light, took all of 10 minutes, my van only had the lense and no bulb part, found the wire on the Ford loom in the bottom of the door and it works.
Obviously it’s not lit up in the picture as I can’t press the brake and take the picture at the same time
Scooby doo wrote:ned wrote:Well that was surprisingly easy, fitted the led 3rd brake light, took all of 10 minutes, my van only had the lense and no bulb part, found the wire on the Ford loom in the bottom of the door and it works.
Pull the brake light switch out the pedal…find this useful when I’m the only idiot available….
Might be calling it quits on the van….not too sure how things are going to go…
Brettbear63 wrote:I jam a block of wood between the seat and the brake pedal
Altransit wrote:Brettbear63 wrote:I jam a block of wood between the seat and the brake pedal
Yes, that's my brake light checker of choice too
blue estate wrote: But most trucks have a bulb check feature
Altransit wrote:blue estate wrote: But most trucks have a bulb check feature
I had something similar on my 1988 Sierra Ghia, but my Focus TitaniumX (with a whole host of "toys" and warnings, has nothing to tell me the brake lights aren't working - That's progress for you
Scooby doo wrote:Altransit wrote:blue estate wrote: But most trucks have a bulb check feature
Only the p’d off motorist who just rammed you as he didn’t know you was braking…
Imagine bmw drivers who see that weird flashing green arrow on the dash feel, they think there’s a bulb gone so never use that switch
