What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby ned » Fri Jan 05, 2018 7:56 pm
blue estate wrote:
bambi mk 1 wrote:
the dutch guy wrote:Q: why are the crankshaft pullys so bloody expensive? best price i can find is 130 euro a piece.
i got the idle rattle but cant tell the difference between the chain tensioner or the pully. and both are quite pricy to fix.
You could try a breakers yard ,they will have loads of them as nobody in their right mind would have a mk6 tdci .
Are you saying Ned is bonkers
I prefer the term special or eccentric lol. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby bambi mk 1 » Fri Jan 05, 2018 8:40 pm
bambi mk 1 wrote:You could try a breakers yard ,they will have loads of them as nobody in their right mind would have a mk6 tdci .
And how long will that thing last? Getting the bleeping thing off is not something id like to repeat often.
I wasn't telling you to fix it ,I was telling you to leave it there :wink:
bambi mk 1
Postby adam75pl » Sat Jan 06, 2018 7:17 am
You are correct, Ned.
“Special” sounds much better;)
This post only expresses opinion of the author of today. It can not be used against him tomorrow, or any other day following that date. In addition, the author reserves the right to change his views, without prior notification.
T280 SWB 2.2 115PS
adam75pl
Postby tony&kasia » Sat Jan 06, 2018 1:12 pm
Fitted a new n/s head light as the motorised level adjuster was jammed :D
Well that's what i told her :lol:
I am going to stick the old head light in the oven on 200c for ten mins & then have a play :?:
Will post some pics as i do it.
I have never liked a sardine can with a bonnet, How can you possibly own the road
tony&kasia
Postby dirtydog » Sat Jan 06, 2018 2:04 pm
tony&kasia wrote:Fitted a new n/s head light as the motorised level adjuster was jammed :D
I would definitely check the o/s headlight just to make sure, there's a good chance that will need changing as well. That's what you should tell Mrs :wink:
dirtydog
Postby adam75pl » Sat Jan 06, 2018 4:34 pm
Drove it. 1100 miles
T280 SWB 2.2 115PS
adam75pl
Postby tony&kasia » Sat Jan 06, 2018 5:06 pm
:lol: Some people do say that if you change one you might as well change the other,
I'm going to see how this one goes first.
tony&kasia
Postby loot » Sat Jan 06, 2018 7:25 pm
I found 2 electric headlight adjusters sitting in the garage doing nothing, I think I'll sell them and buy a new set of 18" alloy wheels for red.
Bloody expensive things them adjusters ain't they :shock: :lol: :lol:
Ids map here
loot
Postby nznikin » Sun Jan 07, 2018 9:35 am
Rust removal on my engine cross member. Electrolysis.
2011 2.4L RWD Duratorq-DI (115PS) – Puma, 6-speed 350 LWB High Roof.
nznikin
Postby withers1 » Sun Jan 07, 2018 10:47 am
Fitted a new door runner all of 5 mins work job well done
withers1
Postby withers1 » Sun Jan 07, 2018 10:49 am
After sucessfull fitting of door runner I applied some shiney bits
withers1
Postby ned » Sun Jan 07, 2018 4:56 pm
Washed it :shock: :shock: N
ned
Postby blue estate » Sun Jan 07, 2018 5:02 pm
ned wrote:Washed it :shock: :shock: N
Arrrrgggh It's the end of the world :shock: :lol: :lol: :lol: :lol:
72plt MG 5 ev estate Battery car
blue estate
Postby ned » Sun Jan 07, 2018 7:27 pm
Looks worse now then it did with an inch of mud on it :roll: N
ned
Postby blue estate » Sun Jan 07, 2018 7:29 pm
That'll teach you :lol: :lol: :lol: :lol:
blue estate
Users browsing this forum: Google Adsense [Bot], simonwood
