What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Thu Aug 19, 2021 6:03 pm
ned wrote:
DG-Unit wrote:[qute="loot"]
DG-Unit wrote:Celebrating my 1 year anniversary on this forum by having my van towed to a garage
Stylishly done :P
Congrats
I joined in 2012
I don't plan on staying long mind, as soon as I get those tyre pressures I asked for I'll be on my way :lol:
31926 posts later :lol:
When you do find out the tyre pressures be sure to never come back and finish the thread with the answer
Ah but 31920 post are about unfinished projects :lol: :lol: :lol: I’m only joking sir loot of Wales :wink:[/quote]
How very rude :?
Remember that post about tyre pressures :P
Which makes 31919 actually :oops: :lol: :lol:
Ids map here
loot
Postby Brettbear63 » Sun Aug 22, 2021 7:52 am
I reattached the breather pipe from the axle , and fitted a curtain to shield the bed when the side doors open 8)
Brettbear63
Postby dirtydog » Sun Aug 22, 2021 4:07 pm
Broke down in the camper this afternoon :x
Then paid £180 for recovery home :cry:
dirtydog
Postby DG-Unit » Mon Aug 23, 2021 4:35 pm
dirtydog wrote:Broke down in the camper this afternoon :x
Ugh. Transits.
2004 Transit SWB 85 T260
DG-Unit
Postby Airthies » Wed Aug 25, 2021 4:51 am
Gave it a birthday of fresh oil and filters, hopefully do the ARB bushes, alternator clutch and Gbox oil tomorrow if it arrives.
Also need to investigate the blend door actuator as the AC is not as cold as I'd expect but it's better when first started than once it's warmed up.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Stephend161 » Fri Aug 27, 2021 9:28 pm
I replaced my steering rack as my old one failed and pissed fluid past the seals into the gators
Here is the thread incase anyone in future needs a how to on removing the steering rack without unbolting the subframe and so on as it is a bit of a puzzle..
viewtopic.php?f=5&t=209809
Stephend161
Postby firststrike » Sat Sep 18, 2021 10:49 pm
Fresh engine oil and filter. Had two containers under the van this time to catch the 9 litres of oil unlike last time when i was only expecting 6ish litres. :lol:
firststrike
Postby Knobby2515 » Sun Sep 19, 2021 3:46 pm
Few things done of late,
Service done, all filters and oils, engine, gearbox and axle.
Got the dents sorted
and now got some decals i wanted done and fitted
2012 MK7
100 T330 2.2 with 150hp Vanunter upgrade
MWB Semi-high roof
2.2 - 6 speed RWD
Air-con, heated screen, front fog lamps, cruise control, twin slide doors
Knobby2515
Postby Noctule » Mon Sep 20, 2021 11:07 pm
MoT today - a pass!
Advisories - 3 for front brakes, new discs and pads will sort all 3, and a slightly noisy front wheel bearing.
Only prep was an oil change and checking all the bulbs (one side light bulb had blown) & horn.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby ropecharrmer » Tue Sep 21, 2021 3:09 pm
Just got FORscan working on my Mac! Now time to plug in try and figure out if my injectors are working properly...
2006 Mk7 2.4 RWD
ropecharrmer
Postby tbullivant » Wed Sep 22, 2021 8:52 pm
Today I cleaned out the inlet manifold, ports and ducting of all the egr crud that had built up. It's now like new (egr blanked off).
I also took off the intercooler, gave it a rinse out with unleaded and tried for about 2 hours to clean the fins of mud and silt. The history of my ex network rail van, states it was recovered from mud/soft sand twice! Every bit of the chassis and body was full of sand/mud as was the drivers headlamp(replaced), so I shouldn't have been so shocked at the weight of the intercooler as it was solid with no air able to pass through it. A very fine flat screwdriver and my compressor with a fine jet has made a huge difference!
2006 2.4 RWD LWB 90/350 hightop - camper conversion
tbullivant
Postby RustWidow » Sat Sep 25, 2021 6:10 pm
Washed KevDogg, he was a bit mucky from our weekend away last week lol
RustWidow
Postby DG-Unit » Tue Oct 05, 2021 5:53 pm
To celebrate 1 year and 45 days of Transit ownership and my birthday I fitted some speakers and have a working stereo :D
It will probably fold in half when I drive it later.
DG-Unit
Postby tbullivant » Mon Oct 11, 2021 9:13 pm
Today I re-attempted (and succeeded) to replace the fuel timing solenoid, what a ballache!
all bolts came out lovely apart from the one torx head on the pump bracket which I had to drill out - I never knew I was a contortionist!
sadly it didn't improve the running, I broke the starter motor and found every little recess of pooled oil which ended up all over me and in my hair. should probably clean the bath now too!
tbullivant
Postby walt1984 » Wed Oct 13, 2021 8:41 am
Rolled over 100,000 miles last week while working away from home.
Lad i was working with was van less after he lent his brother his sport and blew it up.
Came home and treated mine to new oil and filters.
Still having problems with starting from cold and the intake temp reading 50c below actual temperature but getting fed up of going places to be told ' theres no codes'
Sent from my SM-A107F using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
