What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby andz327 » Wed Dec 12, 2018 2:08 pm
loot wrote:
Airthies wrote:
andz327 wrote:It wouldn't be the same if i didn't huv problems a few weeks oot from ChristmasImage
ANDZ
What's it this time sir? Someone else or an inanimate object?
That's a pain in the rectum! Hope it's sorted easy.
Stick a transit custom front on it 8)
Too late, from being written off to this in 3 days.....in the driveway but at least it stayed dryImage
ANDZ
andz327
Postby andz327 » Wed Dec 12, 2018 2:27 pm
ANDZ
Was me rear ending someone that stopped quicker than me..... Need to get that abs working
ANDZ
andz327
Postby paulrichardson » Fri Dec 14, 2018 1:54 pm
Tango330 wrote:Drove ot back from the fire station at 2 this morning and used my led headlights for the first time since I fitted them 8)
well bright too, much better than the night breakers I had on before, and they were pretty good :D
Hi, hope you don't mind me asking, but I fancy some LEDs for my MK7
Where did you get yours from? Were they easy to fit? and finally were they expensive.
Regards,
Paul
paulrichardson
Postby ned » Fri Dec 14, 2018 6:13 pm
Regards,
Paul
EBay is best for LEDs, search led side marker lights, what style are you after?
I have round button ones in my bumper as the longer 6 led ons I had kept breaking wires.
There reasonably cheap and very easy to fit, bit of drilling, bit of soldering wires and heatshrink.
Fitting is easy depending on how you want them to operate, on with side light, on a switch ect.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Tango330 » Sun Dec 16, 2018 4:00 pm
Have you put more on since I saw it N :?: Looks like flippin Blackpool illuminations 8)
Yeah, the ones I had were ebay too, but like Ned says, the longer ones have a tendency to break wires :? Might swap them out for some of the button ones I bought yonks ago.
Still haven't got around fitting the back ones :roll:
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby Tango330 » Sun Dec 16, 2018 4:03 pm
Forgot to say that I just took delivery of another back corner bumper :roll:
Managed to gently tap a street lamp the other weekend, checked it out and no damage, but when I got to where I was going the fecker had fallen off :roll:
At least it was my fault this time, not the pikeys stealing it when it was parked in the services :evil:
T330 RWD now sold
Tango330
Postby ned » Sun Dec 16, 2018 4:10 pm
No they were fitted just not wired in as I removed the halo spots to make some brackets, they are still half make in the shed :oops: think I got 20 button ones for about 6 sovs, the ones in the step came in handy t'other week getting in the van in the pitch black.
I have a spare drivers side upper bumper corner if you need one, proper tailgate one as well.
ned
Postby Airthies » Sun Dec 16, 2018 9:36 pm
Did injector seals again today but think its the rocker cover seals that are the problem need to do them again then sometime. More bolts and washers required now struggling to do the learns again as want it to be all sweet for going to NL for chrimbo but it's too cold outside and the intake temp is too low
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Dec 16, 2018 10:29 pm
Airthies wrote:Did injector seals again today but think its the rocker cover seals that are the problem need to do them again then sometime. More bolts and washers required now struggling to do the learns again as want it to be all sweet for going to NL for chrimbo but it's too cold outside and the intake temp is too low
Hair dryer :P
Ids map here
loot
Postby Airthies » Sun Dec 16, 2018 10:34 pm
Hair dryer :P
It's being a royal twat tonight now not doing learns. failing with error code 90 Image
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Dec 16, 2018 10:47 pm
Hair dryer :P
Never done it on forscan, ids has the green bars hasn't it, yours saying cancelled pilot?
Can't you raise the intake air temp?
Ids map here
loot
Postby Airthies » Sun Dec 16, 2018 11:00 pm
loot wrote:
Airthies wrote:
loot wrote:[quote="Airthies"]Did injector seals again today but think its the rocker cover seals that are the problem need to do them again then sometime. More bolts and washers required now struggling to do the learns again as want it to be all sweet for going to NL for chrimbo but it's too cold outside and the intake temp is too low
Hair dryer :P
Can't you raise the intake air temp?[/quote]Got intake temp up eventually but then failing learns, decided to do things backwards reset counters then pump learn then pilot learn worked now and no codes. see how long it lasts... my feet are freezing now
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Sun Dec 16, 2018 11:00 pm
Lol still a result 8)
Ids map here
loot
Postby Airthies » Sun Dec 16, 2018 11:45 pm
Oh and my VCM is kaput so did it all with foreskin and a bit of elm.
Or there's something else happening as the computer can see the VCM as a device but forscan, IDS and the Bosch VCM manager can't see it
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Mon Dec 17, 2018 12:21 am
Airthies wrote:Oh and my VCM is kaput so did it all with foreskin and a bit of elm.
If the vcm2 is seen then it should work, have you done a full pc wipe and reload and changed the usb cable? Also pin reset the vcm.
Ids map here
loot
