What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby Airthies » Fri Jan 04, 2019 12:06 am
loot wrote:Looks alright to me :shock:
Have you got a block diagram of how the gearbox works?
Is it a simple process or do things need to be timed? Are there safeties that need to be incorporated?
And most importantly do you have all the different coloured lamps?
https://youtu.be/Qa_gZ_7sdZg
I'm sorry but it will have to go from green straight to red alert (with a brief stop at yellow for a pee) as I do not have blue bulbs
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Tango330 » Sun Jan 06, 2019 2:09 pm
Airthies wrote:
loot wrote:
Airthies wrote:I put mine back up on the ramps and have a headache now....
Bloody bright ideas.....
Haven't you done that little job yet? Thought it would be voice activated or something by now :P
My heads bursting, just when I think I'm getting somewhere I realise I'm getting a bit ahead of myself and I'm back to nearly but not quite square one.... so at least still moving forward... if only just
Meant to get a pick of my latest puzzle but here's one of the current steep learning curve
Foook :!: :shock:
Is that electronic 4x4 transfer box control :?:
Is this part of a Ranger project by any chance :?:
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby Airthies » Sun Jan 06, 2019 2:25 pm
Tango330 wrote:
Is this .... :?:
Yup
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Tango330 » Tue Jan 08, 2019 11:22 am
Airthies wrote:
Tango330 wrote:
Is this .... :?:
Yup
Cool 8) Can't wait :)
T330 RWD now sold
Tango330
Postby dirtydog » Sat Jan 12, 2019 11:54 am
I think someone may have tried to have one of my alloys away, noticed a rumble/knocking when cornering right last night but it was too dark to check anything.
Had a look first thing this morning and found a broken wheel stud and the 3 other normal wheel nuts were a bit loose, locking wheel nut was fine though :shock:
dirtydog
Postby loot » Sat Jan 12, 2019 12:43 pm
dirtydog wrote:I think someone may have tried to have one of my alloys away, noticed a rumble/knocking when cornering right last night but it was too dark to check anything.
Is possible dd but on my mk7 i was tightening the nuts up and a few of them weren't getting tight and the bolts sheared like yours, probably from being over done many times, the worrying thing was that the fact that it was easy to tighten until snap, that suggested that rather than just fail, my bolts stretched and probably split more and more, I think that I could have happily just left it and it popped off when I was driving or a bump etc. Luckily they are hub centric so only needed to keep the wheel on the hub.
There are ppl with wellers on that the centre isn't touching :? Not Ned though he's sensible :P
Ids map here
loot
Postby dirtydog » Sat Jan 12, 2019 1:20 pm
Well I've ordered a new set of studs and nuts so I can change all on that hub
dirtydog
Postby ned » Sat Jan 12, 2019 4:38 pm
Yes I have seen people with Weller's just on the studs :shock: its not a risk I would take, my centres have gone all rusty now though :(
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby SammiG » Fri Jan 18, 2019 11:57 pm
Removed the bulkhead, fitted a load area carpet and started the look for a single passenger seat and the inevitable unicorn poop doorcard
SammiG
Postby FFMan » Sat Jan 19, 2019 11:23 pm
I installed a home made Nixie tube based speedo & clock. Clock changes to speed on the move :-) Don't know why but it amuses me no end.
FFMan
Postby ned » Mon Jan 21, 2019 10:14 pm
Finally found the cause of the squeaking rattling noise coming from the engine bay, t'would appear my alternator is on borrowed time :( or at least the bearing are.
ned
Postby Mad Husky » Tue Jan 22, 2019 5:04 pm
ned wrote:Finally found the cause of the squeaking rattling noise coming from the engine bay, t'would appear my alternator is on borrowed time :( or at least the bearing are.
Cheers for the idea mine squeaks when warm but today fitted a new battery as the other needed jump starting after one turn this morning, while i was at it fitted the split charge inteligent relay with fridge output woooo. on a down side it snowed while i did it and my seat is now wet.
Mad Husky
Postby ned » Tue Jan 22, 2019 7:17 pm
Is yours a Mk6 or 7?
I only found the fault when I put the heated screen on, it was dark, all the lights and heating on, then as soon as I pushed the heated screen button the valtage droped and it started squealing and rattling :roll:
Mk7 suffer from crank pulley breaking (usually rattle a few weeks before)
ned
Postby Mad Husky » Tue Jan 22, 2019 8:17 pm
Mines a 6 never squeaked when i turned on the screen this morning but once warm it does, I thought it was the belt but van was nore powerfull with the new battery don't know why.
Mad Husky
Postby ned » Tue Jan 22, 2019 8:20 pm
Mines a 6 never squeaked when i turned on the screen this morning but once warm it does, I thought it was the belt but van was nore powerfull with the new battery don't know why.[/quote]
Wonder if it's the bearing in the alternator is dry, if it only does it when hot, mines all the bloody time :?
ned
