What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby Bill W » Fri Oct 12, 2018 7:00 pm
I got the rust-bucket indoors late afternoon, ready for changing the driver's side CV joint tomorrow. While I was there, I got a ladder and looked on the MH roof. I almost wish I hadn't. Front and back seams both extensively rusted, with several holes. Looks like a big derust and fibreglassing job coming up. :( On the bright side, I also removed the lower left door catch and freed it up with lots of duck oil and screwdriver wiggling. Now back on and working well. :D
Bill W
Postby Bill W » Sat Oct 13, 2018 4:25 pm
I set about changing the knackered driver's side CV joint this morning. It turned out to be a pig of a job. I didn't have a ball-joint splitter, so I had a hell of a job to get the bottom ball joint out. Finally, after masses of smacking, it gave in. Getting the CV jont to come off the drive shaft was even worse. I assumed that like other CVs I've done, it would pop off with a few sharp smacks from behind. OH no! This one was having none of it whatsoever. I ended up hitting it so hard, and so many times, that the balls flew out and the outer joint came away. I then ended up slicing through the remaining part of the inner race (pictured) in two places with a slitting disc in the angle grinder. I took care not to cut through to the splines on the shaft, then chopped through the last tiny bit with hammer and old screwdriver. Putting the new CV kit in was straightforward and I made sure I greased all splines before putting back together. ook it for a spin round the block and deep joy, no more clacking on corners. :D :D :D
Bill W
Postby ned » Sat Oct 13, 2018 5:09 pm
So you did the CV in situ, I was going to.remove the drive shaft but if I get time next week do it in situ :D
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Bill W » Sat Oct 13, 2018 5:18 pm
ned wrote:So you did the CV in situ, I was going to.remove the drive shaft but if I get time next week do it in situ :D
I didn't want to pull out the driveshaft and have gearbox oil all over the place. In hindsight, it might have been quicker and less hassle to remove the shaft and put it in the vice. At least you can get a decent swing at it with the hammer.
Bill W
Postby ned » Sat Oct 13, 2018 7:44 pm
That's what I was thinking but same as yourself don't want to spill gearbox oil all over the driveway, its the passenger side on mine.
ned
Postby Bill W » Sat Oct 13, 2018 7:52 pm
Oh nice. Can't beat a bit of rolling around on the ground outdoors, up to your eyes in grease, mud and rust. :lol: Just needs to be a gravel drive to really put the icing on the cake. :D
Bill W
Postby loot » Sat Oct 13, 2018 8:02 pm
Precisely why I don't do it :lol:
Customers don't realise that.
A. You don't get the parts for cost.
B.you don't have all the fancy tools because you can't afford them plus vat etc.
C. You have no ramps etc so end up rolling about on the floor in the elements potentially risking your health from the elements and or stability of the vehicle perched on a rusty Halfords axle stand that is missing its hardened steel pin and has an aluminium tube in ( :lol:) not mine :?
And then it's, can you do it cheaper than the garage mate you don't have their overheads :lol:
Ooh please can I lie in the floor for 2 hours covered in shite for 15 pounds :P
Nobbers eh :x
Ids map here
loot
Postby ned » Sat Oct 13, 2018 8:04 pm
Aye it's mighty fun lay on your back fannying around under the van :lol: luckily it's a tarmac drive but I have had to cut some out and relay it due to oil spills, er indoors goes mad at me over the mess :shock:
ned
Postby ned » Sat Oct 13, 2018 8:13 pm
loot wrote:Precisely why I don't do it :lol:
Nobbers eh :x
So if I wait for the lair to open it'll be 25 sovs plus tea n biscuits :wink: :lol:
ned
Postby loot » Sat Oct 13, 2018 8:35 pm
Nobbers eh :x
No i have overheads please £65 ph :lol:
Ids map here
loot
Postby ned » Sat Oct 13, 2018 8:57 pm
Nobbers eh :x
Deal, I'm on my way :lol: I was quoted 80 for the job but then frog blew up so needed the van on the road :roll:
ned
Postby loot » Sat Oct 13, 2018 9:27 pm
ned wrote:[qote="loot"]
Nobbers eh :x
Deal, I'm on my way :lol: I was quoted 80 for the job but then frog blew up so needed the van on the road :roll:[/quote]
Yes 65 until I look at it and think of a reason why it's 100 now, maybe needs a long stand or some tartan paint which is very expensive you know :lol:
Ids map here
loot
Postby ned » Sat Oct 13, 2018 9:37 pm
The long stand it what cost more, you may even need a left handed hammer with it being on the left, so that's now 150 + vat, oh and now it need disc pads and berings :shock: sounds like quick fit :lol:
ned
Postby Tango330 » Mon Oct 15, 2018 10:33 am
Took the tango van in to get the rear disks done cause I needed it on the road quick :oops:
Plus couldn't face doing the 400 N nut thingy again, had to put an 8 foot scaffold tube on the bar to undo it last time :shock:
Coming up your way on Friday N, do you still want me to pick that wing up from Al :?:
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Postby Punto443 » Mon Oct 15, 2018 1:15 pm
How far up are you coming mike?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
