What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby dirtydog » Wed Jun 09, 2021 4:08 pm
Been waiting for a delivery for most of the day so took tango to the tyre/exhaust place across the road from the job I'm on to get the air con gassed up, unfortunately there's a leak in the system somewhere
So then I took it up the garage for the jet wash, spent about 20 minutes in there giving it a good clean. Could do with some more time but I ran out of coins
dirtydog
Postby RustWidow » Thu Jun 10, 2021 10:37 pm
dirtydog wrote:Been waiting for a delivery for most of the day so took tango to the tyre/exhaust place across the road from the job I'm on to get the air con gassed up, unfortunately there's a leak in the system somewhere
Well done DD, I shall look forward to seeing what you do to her
RustWidow
Postby karl » Thu Jun 10, 2021 11:02 pm
mines just getting neglected not as prestain as it was a few years ago after the paint job it had :(
karl
Tranny Lover!!!
Postby Brettbear63 » Fri Jun 11, 2021 6:35 am
I got a new gear selector arm fitted .
Brettbear63
Postby ned » Fri Jun 11, 2021 2:28 pm
About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres 8)
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby andz327 » Fri Jun 11, 2021 6:09 pm
ned wrote:About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres 8)
I phoned a breakdoon wagon for mine does that countImageImage
Sent from my SM-G975F using Tapatalk
andz327
Postby ned » Fri Jun 11, 2021 6:26 pm
Oh dear, not the oil cooler again surely, can’t be no enough oil on the headlight, wing, bonnet :shock:
ned
Postby andz327 » Fri Jun 11, 2021 7:21 pm
Fuel pipe holed....... high pressure metal pipe from pump to rail
Waited over 2hrs for breakdown wagon only for a dude in a discovery to tell me ma pipe is fooked...... towed with a rope 2mls to get off motorway then told I'll be waiting more hours for a wagon
andz327
Postby ned » Fri Jun 11, 2021 7:27 pm
andz327 wrote:
ned wrote:
andz327"quote="ned wrote:About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres 8)
Sent from my SM-G975F using Tapatalk[/quote]
a***holes aren’t they, at least your off the motorway, so low loader all the way home, where are you this time, not Cornwall I hope.
ned
Postby andz327 » Fri Jun 11, 2021 9:05 pm
ned wrote:
andz327 wrote:
ned wrote:[quote="andz327"quote="ned"]About to throw sparks everywhere, bit of trimming of the plastic and some cutting of metal, now they should give me enough clearance on the front tyres 8)
a***holes aren’t they, at least your off the motorway, so low loader all the way home, where are you this time, not Cornwall I hope.[/quote]Kinda local for a change......
Lockerbie
andz327
Postby andz327 » Sat Jun 12, 2021 12:54 am
All sorted and back on the roadImage
andz327
Postby ned » Sat Jun 12, 2021 7:05 am
andz327 wrote:All sorted and back on the roadImage
Now that’s what you call a rapid recovery 8) what are those pipes made from? You got me thinking now, the fuel supply and return pipes entering the pump on ol’ lucie are well rusted, wonder if it’s got a pin prick hole in causing air ingress :? Lockerbie wasn’t too bad for it to brake, at least you was north of the boarder
ned
Postby ned » Sat Jun 12, 2021 5:55 pm
Made a mess on my front lawn,
Point of no return :shock:
Anyone want to buy some rare not very rust mk6 parts,
ned
Postby ned » Sat Jun 12, 2021 6:01 pm
Gained 4 inches of clearance on the front tyres, made a bit of a mess with the sikoflex though, I even painted the wheel centres with some black paint :P
ned
Postby loot » Sat Jun 12, 2021 6:43 pm
Will done Andz was that a spare pipe you had? Not the type of thing you'd expect to pop though :shock:
Ids map here
loot
