What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby motorman116 » Tue Sep 18, 2018 5:58 pm
blue estate wrote:
motorman116 wrote:Just to cheer you all up....
I washed, dried, polished and applied 2 coats of wax on my van today :lol:
:shock: Now just waiting for the snide remarks, :roll: I wonder who it will be first.... :lol:
FFs ! No wonder it’s blowing a gale and peeing down
:shock: Hmmm I thought that it would be you :lol:
By the way, its been blowing a gale all day, wasn't much fun cleaning the roof in the wind :lol:
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby blue estate » Tue Sep 18, 2018 6:03 pm
It’s even less fun driving a 44t curtain sided that’s empty along the M6
72plt MG 5 ev estate Battery car
blue estate
Postby ned » Tue Sep 18, 2018 8:43 pm
Sent from my iPad using Tapatalk[/quote]
Do you not drive with the curtains open in windy conditions?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby blue estate » Tue Sep 18, 2018 9:07 pm
ned wrote:
blue estate wrote:
motorman116"uote="blue estate wrote:[quote="motorman116"]Just to cheer you all up....
Do you not drive with the curtains open in windy conditions?[/quote]
No Ned as most modern trailers only have a tin or thick plastic sheet roof which is only pop riveted down , so any side gust could literally blow the roof off
blue estate
Postby ned » Tue Sep 18, 2018 9:10 pm
Ah that makes sense, my iveco had a shitty perspex roof, it used to leak like mad :lol:
ned
Postby blue estate » Tue Sep 18, 2018 9:15 pm
ned wrote:Ah that makes sense, my iveco had a shitty perspex roof, it used to leak like mad :lol:
The trailer I’ve got on has a tin roof , but my 6 wheeler had a fibreglass roof
Mr flip flop could fold curtains back and his roof as continental trailers can do that
blue estate
Postby ned » Tue Sep 18, 2018 9:25 pm
That's why I asked as I do see a few foreign HGV around here driving with the curtains back
ned
Postby andz327 » Tue Sep 18, 2018 9:38 pm
antcull01 wrote:Not today but over the past week I managed to shear 2 bolts in the chassis leg for the gearbox mount, Burnt through about 30 drill bits and a cordless drill trying to unsuccessfully drill them out. So I had to cut the chassis leg, remove the captive nuts and weld 2 new ones in. Then weld the chassis leg back up, then it was mot time and she failed on 2 front tyres which I replaced and retested with a pass. Welds look a bit rough but they are strong and I put a plate in behind to reinforce it a bitImageImageImageImageImage
Sent from my LDN-L01 using Tapatalk
Damn thats some pigeon sh*t mate, there's as many holes as there is blobs...... You must have done the tenner in the ashtray trick when in for MOT mate hahaha
Sent from my LG-H870 using Tapatalk
andz327
Postby antcull01 » Wed Sep 19, 2018 9:38 am
It does look better than that now just not took any more pictures, it was ground back and welded again then sprayed silver as that is all I had and just wanted to protect against rust. Still gonna grind it back again and set the welder up properly, get it looking good then paint it properly but working 6 days doesn't make it easy
antcull01
Postby loot » Wed Sep 19, 2018 10:09 am
I wouldn't bother really just get some thick underseal spray like shutz and blast the underneath of the van :D
Ids map here
loot
Postby antcull01 » Wed Sep 19, 2018 10:13 am
Yeh might just do that
antcull01
Postby motorman116 » Fri Sep 21, 2018 1:21 pm
Fitted 2 x front shock absorbers, 2 x front coil springs and 2 x front top mounts. Then carried out an alignment...
motorman116
Postby loot » Fri Sep 21, 2018 1:37 pm
motorman116 wrote:Fitted 2 x front shock absorbers, 2 x front coil springs and 2 x front top mounts. Then carried out an alignment...
Did it need them or just pre maintenance? 8)
I only replaced 1 top mount on mine, the arse of a job it was and the fact that the original was mint made it pointless doing the second :?
Plus cutting the carpet made me cry :lol:
Ids map here
loot
Postby motorman116 » Fri Sep 21, 2018 1:55 pm
The N/S/F shock absorber was knocking internally , and the coil spring on that side broke on Wednesday morning. So I just decided to replace the whole lot both sides, seeing that they was the same age and covered the same amount of miles.
Sent from my SM-G960F using Tapatalk
motorman116
Postby Tango330 » Sun Sep 23, 2018 5:55 pm
Finally got around to doing the rear disks and pads on the Tango van. Plus swapped out the track rod ends, which cured the rattling :D
T330 RWD now sold
Ford Ranger Wildtrack now sold
MI 5 sacked me from my job as an interrogator this morning, didn't like to ask why :?
Tango330
Users browsing this forum: Google [Bot], knobby1, metalworker0
