What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby birdie » Thu Feb 08, 2018 12:02 am
Are they easy enough to wire up?
mk7 T350 FWD towing van
birdie
Postby andz327 » Thu Feb 08, 2018 12:07 am
ned wrote:
squirrel93 wrote:
ned wrote: no, I had to leave it at a job cos the evil thing won't go in gear :roll: so after some shouting at it I walked off :? Kinda miss it not being outside :( :cry: N
I have the selector from mines complete if you want it posted ?
If it makes you feel better the mk6 ate the clutch today , it’s booked in for tomorrow
Ay up are kid, how much do you want for the selector :?: its working again for now but how long for is the question, it seems I'm having to cover it in wd40 every other month these days :roll:
Just order a new front bearing as that's whining like a 2 year old, these trusty old vans needing parts eh, there not fit for purpose N
No the new bearing is it Ned
andz327
Postby ned » Thu Feb 08, 2018 12:51 am
andz327 wrote:
No the new bearing is it Ned[/quote]
Luckily not Mr Andz Sir t'is the side I put the new spring on, I have the part just not had the time to do it :roll: bloody work keeps getting in the way, how's your new engine going :?: :D N
03 transit 125t280 2.0 tdci swb executive college blue 92 crewcab. Built in Belgium so deserves lots of love. 218,000 miles on the clock.
Instructions for use. fill with fuel. start engine. drive like a t#@t.
ned
Postby Airthies » Thu Feb 08, 2018 1:13 am
What's the thread on the brake pipe fittings on these vans? Metric or imperial?
Just ordering up some bits prior to the mot.....
Back now, well for a bit anyway.....
2008 350LWB 115PS ex fitters van + other things....
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Thu Feb 08, 2018 1:15 am
ned wrote:
Luckily not Mr Andz Sir t'is the side I put the new spring on, I have the part just not had the time to do it :roll: bloody work keeps getting in the way, how's your new engine going :?: :D N[/quote]
andz327
Postby andz327 » Thu Feb 08, 2018 3:34 am
andz327 wrote:
[/quote]Aye the new old engine is good mate, just wish i had the work to go with it mate
andz327
Postby Brains_transit » Thu Feb 08, 2018 5:52 pm
Found the problem why it wouldn't turn over the glow plug live had chafed where it follows the shape of the engine and was earthing :x the main starter earth is either a bad connection or water had corroded it internally but I can drive it with a jump lead from the starter bolt to the front arch :lol:
Brains_transit
Postby Airthies » Thu Feb 08, 2018 6:25 pm
Brains_transit wrote:Found the problem why it wouldn't turn over the glow plug live had chafed where it follows the shape of the engine and was earthing :x the main starter earth is either a bad connection or water had corroded it internally but I can drive it with a jump lead from the starter bolt to the front arch
The engine earth cable corrosion is what I put down to why my van was frying electronic modules for a while. Both ends of the earth seemed ok but the internals of the cable were shot!
V86+patch
V86.04
X-Prog
C81
Airthies
Postby motorman116 » Thu Feb 08, 2018 6:36 pm
Fitted 2 x antiroll bar D bushes and N/S/R Brake caliper... Blasted parking brake lever kept on sticking on :( and no more knocking from the front :D
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby dirtydog » Thu Feb 08, 2018 9:59 pm
Airthies wrote:What's the thread on the brake pipe fittings on these vans? Metric or imperial?
They're metric, I bought some at the weekend from Halfrauds
2006 Mk7 115 350
dirtydog
Postby Airthies » Thu Feb 08, 2018 10:03 pm
Cheers DD got an assortment box ordered so I'm gonna have plenty now.
It's mostly metric with a couple of imperial fittings which will be handy when I come to do the mini (If I ever get the time...)
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Brains_transit » Thu Feb 08, 2018 10:21 pm
Yeah designed to fail with the wire at the chassis leg on line with the waterfall when it rains
Brains_transit
Postby Pete.s » Thu Feb 08, 2018 11:23 pm
Fitted the steel bulkhead and me new LED' lights in the back
If its got T*ts or Tyres yr in for Trouble :lol:
Pete.s
Postby HuMpH » Thu Feb 08, 2018 11:44 pm
Nice ..which leds you got ? They’re not the strip type that cut to length are they ? Can’t tell on phone lol
When they go out are they completely off or does 1 stay very dim.
Never seen those fitted panels over cab before either, very posh
125 T350 Lwb Hitop Rwd now sold.
Mk7 110 T300 Fwd
T-shirts preview Here
HuMpH
Postby ned » Thu Feb 08, 2018 11:45 pm
Pete.s wrote:Fitted the steel bulkhead and me new LED' lights in the back
I always think ford should have fitted a small hatch to access the battery through the bulkhead. N
ned
Users browsing this forum: Google [Bot], kangaben
