What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby Airthies » Mon Feb 12, 2018 10:59 pm
Ordered an modded elm 327 for it
Back now, well for a bit anyway.....
2008 350LWB 115PS ex fitters van + other things....
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Mon Feb 12, 2018 11:26 pm
Has anyone had code 39 pilot learn failure? I've tried everything I can so far but we're looking at pcm issues or wiring unless someone has had this 1 before?
Mk7 56 plate 2.2
Ids map here
loot
Postby Airthies » Tue Feb 13, 2018 1:08 am
loot wrote:Has anyone had code 39 pilot learn failure? I've tried everything I can so far but we're looking at pcm issues or wiring unless someone has had this 1 before?
Mk7 56 plate 2.2
Erm..... nope!
Sorry dude
V86+patch
V86.04
X-Prog
C81
Airthies
Postby squirrel93 » Tue Feb 13, 2018 9:24 am
Mk7 56 plate 2.2
I’m sure I had this on one of our 110 56 plate mk7s Morgan Ids couldn’t do anything because of it ? Not 100% but I never resolved the fault , sold the van on
squirrel93
Postby loot » Tue Feb 13, 2018 11:16 am
Mk7 56 plate 2.2
Thanks, it's been to a few places including Ford who couldn't fix it.
Genuine parts used and everything checks out, live data good, power good etc.
It's not often I get to this point where a decision needs to be made but I'm looking at changing pcm over to see if it is a programming problem.
No fault codes either apart from engine malfunction which was there originally and due to pilot not learnt and brake wear indicator on.
Ids map here
loot
Postby birdie » Tue Feb 13, 2018 5:57 pm
Checked my van to see what wiring I had for a heated screen, appears I only have the switch wiring. How hard is it to create a loom using timer relays?
mk7 T350 FWD towing van
birdie
Postby Airthies » Tue Feb 13, 2018 8:19 pm
birdie wrote:Checked my van to see what wiring I had for a heated screen, appears I only have the switch wiring. How hard is it to create a loom using timer relays?
Scrappies and get the extra harness I got one for about a tenner just plug n play and activate.
I think.....
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Tue Feb 13, 2018 8:24 pm
Whoop!
MOT time....
Full brake line replacement.
Brake balance on front.
Handbrake efficiency.
And this barsteward Image
Getting phyzick on it now! Image
Will now require welding too
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Punto443 » Tue Feb 13, 2018 8:26 pm
Mk7 56 plate 2.2
Think I remember that Dean? Was that the one that said injector current fault or something?
The tonic blue one with the masking tape square on the back panel :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
2011 qashqai.
2003 jimny
Punto443
Postby squirrel93 » Tue Feb 13, 2018 8:34 pm
Punto443 wrote:
Mk7 56 plate 2.2
Yeah that’s the one mate , I’m sure you made a post of emailed loot about it but I never bothered with it
squirrel93
Postby dirtydog » Tue Feb 13, 2018 9:27 pm
Picked up a new bulkhead for mine this morning, it's one of the carpeted ones as well 8)
2006 Mk7 115 350
dirtydog
Postby dirtydog » Tue Feb 13, 2018 11:51 pm
And my new sump pan arrived today as well, not sure if I'll have time to fit it this week though :roll:
2006 Mk7 115 350
dirtydog
Postby Airthies » Wed Feb 14, 2018 12:00 am
So that's about 4hrs to get a wishbone out and the rear bolt and bush sleeve are actually still there getting too old for this laying on the ground faffing around under vehicles!
It's a grinder job tomorrow! Too late at night for it now! Image at least I got to it eventually.Imagebut the bolts tight in the sleeve
Imageit's bloody tight in the sleeveImageit's too bloody tight it'll get the grinder work tomorrow.
And bad mood stopped play
Not just bloody cold temps....
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Pete.s » Wed Feb 14, 2018 12:11 am
good effort with the adapted puller, looks like Mk7 owners should get these fittings greased up to halt the corrosion
If its got T*ts or Tyres yr in for Trouble :lol:
Pete.s
Postby andz327 » Wed Feb 14, 2018 1:01 am
Airthies wrote:So that's about 4hrs to get a wishbone out and the rear bolt and bush sleeve are actually still there getting too old for this laying on the ground faffing around under vehicles!
Welcome to my world mate
andz327
