You get the torx screw out the back ok then?Punto443 wrote:Rear caliper rebuild day
Airthies wrote:You get the torx screw out the back ok then?Punto443 wrote:Rear caliper rebuild day
dirtydog wrote:Brake pad warning light is sorted, broken wire on the rear axle.
Just the abs/esp to sort out now, diagnostics says its rear passenger side, replaced the sensor but codes come back straight away.
dirtydog wrote:Yeah have checked my ring it's fine
