unknown fault codes
unknown fault codes
Postby jdm2506 » Thu May 17, 2012 7:45 am
van stoped on road checked the usual visable and mechanical .Had to check with FCR found multiple fault codes repaired broken wires behind starter motor where they rub on rear of starter,Now i am left with 3 faults (fuel pump timming control Cct malfunction) & 2 which read (unknown 5721 & 5733) This is a transit 85/260 . 06 reg 2.0l duratorqu TD di .I have used Ask a ford mechanic but so far i have not recived any answer .
my thanks to any member who has the knowledge to help.
Cheers.
jdm2506
Re: unknown fault codes
Postby Dan T » Thu May 17, 2012 2:25 pm
Do you have any 'P codes' ?
Dan T
Postby jdm2506 » Thu May 17, 2012 6:47 pm
Hi Dan ,there are no p codes
jdm2506
Postby Dan T » Thu May 17, 2012 7:19 pm
What are you reading the codes with ?
Dan T
Postby jdm2506 » Fri May 18, 2012 8:24 am
Hi Dan ,The fcr is a SPX TECNOTEST REFLEX 3I3O
CHEERS
jdm2506
Postby Dan T » Fri May 18, 2012 10:38 am
You'll need to try another machine on it that will give you the p codes.
Dan T
Postby jdm2506 » Fri May 18, 2012 11:45 pm
Hi dan . I have had 3 other scan tools connected + this is the only fcr that makes any communication with the ecu ,but it has to be set to ford OBD ,If iset it to OBD/OBD2/EOBD it says the same as the others (no communication with ecu) I'l need to get an engine managment wireing diagram & check the Cct
Cheers
jdm2506
Postby ake » Sat May 19, 2012 9:16 am
Also check all the fuses
Postby jdm2506 » Sun May 20, 2012 6:27 am
Have checked all fuses acouple of times ,but i am going to check them again
cheers
jdm2506
Postby jdm2506 » Tue May 22, 2012 12:43 am
Have'nt found what the odd fault codes ment, however ,found 1 broken wire & 2 bare wires in loom going to fuel pump ,& a disconected terminal in fuse box ,repaired them ,van now runs & codes have vanished..
Thanks to the members who have given thier advice & asistance cheers
jdm2506
