The problem:
I'm having an intermittent problem with the passenger door lock. When locked by a single press of the key, by pressing the locking tab on the driver's door handle, or by the anti-hijack locking, sometimes it will not open by pulling the handle, i.e. it is behaving as if deadlocked. This is inconvenient for me because I often have to park up against a wall and climb out of the passenger door, but it represents a safety hazard because a passenger would not be able to open the door in emergency. The door will deadlock and open normally with the key. There is sometimes an unusual grinding sound from the lock when it is operated from the outside, using the key fob.
The warranty runs out next week. Does anyone know if a pre-existing and previously reported fault is still covered after the end of the normal warranty period?
See also: viewtopic.php?p=933144#p933144
