transitbarrow wrote:checked all fuses non blown .. plenty power in both batteries .. turn key immobiliser light goes out go to crank engine absolutely nothing
Please please someone must have some ideas !
transitbarrow wrote: Am i right in thinking if its starter motor thats knackered it could at least click on ignition key in crank position ?
Altransit wrote:transitbarrow wrote: Am i right in thinking if its starter motor thats knackered it could at least click on ignition key in crank position ?
Not necessarily, it could well be the starter, or the wires going to it, if you've definitely checked all the battery connections
Check to see if you have voltage on the starter terminals
welderman1 wrote:Hi, Newbie here. im having exact same symptoms on 08 dropside truck, its 2.4 rwd, did you find the fault?
