ibrooks wrote:Was there ever a resolution to this? Mine does the same and it bugs me as it pushes the mirror forwards a bit and it doesn't spring back so when I get in I can't see a thing and have to pull the mirror back into it's normal position. Surely the door shouldn't open that far? Is there a common problem I should look at with the check strap? I've had a quick look from the outside and there's nothing obvious wrong - although there is a hell of a cracking noise from it as the door opens.
