260 2.0 TDCI (125) has an intermittent starting problem, when the van does start it runs perfectly smooth and plenty of power
The problem can happen when its hot or cold, here is what's been done so far,
Fuel filter housing changed,
New cam sensor,
New crank sensor,
Injectors removed tested and recoded,
New battery
Van was running fine for a day after the work,but then refused to start,turns over but won't fire,,
No issue with the Immobliser light it goes out after key in position 2
Here are the codes showing now,
Po623. Generator lamp control circuit
P1211. Injector control pressure higher/lower than desired (engine running)
P0340. Camshaft position sensor A circuit (bank 1 or single sensor)
P1608. Fuel injection pump watchdog signal lost
P0191. Fuel rail pressure sensor circuit range/performance
P0251. Injection pump fuel metering control A
If it was the pump surely the van would not run as sweet when it does decide to start?
Are there any other switches or sensors I should be looking at? Faulty ecu mabey?
Would be great full for any help
