jonny24 wrote:It defiantly says P062B internal control module fuel injector control performance circuit voltage below threshold
It's a FWD 2.2 tdci but da desiel knock only seems to happen when on first start up when engine is warm sounds ok
It also says on the machine to replace module if the fault still exists does that mean the fuel pump or something that controls the fuel pump
angeleye wrote:where are you getting your codes interpretations from![]()
p0268 is cylinder 3 injector circuit high voltage.
is van running rough /idle ok![]()
have you a service light on...check wiring to injectors/dirty injector /faulty injector/
karl mcghee wrote:angeleye wrote:where are you getting your codes interpretations from![]()
Your is wrong code read it
Its p 0628 I mentioned not p0268
You come across as an arrogant person !!!!!
Wot is your trade ????
angeleye wrote:karl mcghee wrote:angeleye wrote:where are you getting your codes interpretations from![]()
i apologise for reading your code wrongly.
as for being arrogant i only think i am![]()
wot is your trade are you a manc trying to speak german,
jonny24 wrote:My trade is a high reach window cleaning specialist sorry if I seem arrogant just trying to solve my problems on my transit having no luck with the main dealersGot to change my 18 month old egr valve due to the signal being erratic the egr don't seem to last very long
jonny24 wrote:Yeah money is really good mate if my bloody transit stops draining my profit due to all the faults with it lol egr is a bloody pain lol
