transit330/2.4 fuel fault?
Postby simtech » Fri Feb 16, 2007 11:14 am
Got a 2003/2.4 90ps model, runs fine starts first time,fault occurs when you accelerate hard,the engine misses as if it is starved of fuel.This does not happen when engine not under load you can rev to max no smoke or nasty noises.Been on a diagnostic no elec fault shows.Any suggestions guys . :? :?
simtech
Postby BigNeil » Fri Feb 16, 2007 11:17 am
Hi
am no expert.
does it need the accelerator cable adjusted?
air intake?
as i said no expert, but these two were the things wrong with my transit lately.
BigNeil
Postby thunderider » Fri Feb 16, 2007 8:03 pm
try changing the fuel filter, i had this kinda thing over taking on the motorway,its the cheapest easiest option.
I am the god of hell fire.....
thunderider
Postby blindbeggar » Sat Feb 17, 2007 1:28 am
If it's not any of the above check too see if the waste gate is fully opening, thats what was wrong with mine.
blindbeggar
Postby simtech » Tue Feb 20, 2007 7:00 pm
Had a go at the waste gate,but unable to disconnect due to corrosion around the connection to the gate.Had a quick trip up the road and the fault has gone don't know wether i may have cured it whilst trying to dismantle it .Thanks for the advice .
simtech
Postby thunderider » Fri Feb 23, 2007 8:23 pm
blindbeggar wrote:If it's not any of the above check too see if the waste gate is fully opening, thats what was wrong with mine.
so you still hooning around europe with it?
thunderider
Users browsing this forum: Google [Bot], Google Adsense [Bot], Trev_
