MK 7 Bluetooth ?
MK 7 Bluetooth ?
Postby THE VIKING » Wed Feb 21, 2007 9:27 pm
Hi there does anybody know if I was to amp my front speakers would I loose the blue tooth on the factory radio ? If I was thinking of useing high level input to the amp would the blue tooth still work ?
THE VIKING
Postby Nighthawk » Wed Feb 21, 2007 9:56 pm
are you keeping the head unit?
if your just going to run the speaker leads out of the headunit, into the amp and then the amp wiring going to the speakers, the signal from the PSE module will remain unchanged, so phone audio and voice command will also be amplified.
Transit.........Job done
Nighthawk
Postby THE VIKING » Wed Feb 21, 2007 10:03 pm
Thanks for your reply
THE VIKING
