Van will not move after parked for a couple of days
Postby bikehunter » Sun Feb 25, 2007 10:36 pm
I have a FWD 2ltr van and after a fews days parked it refuses to go forward. Continuing with some perseverance there is a bang of what can only be thought as brakes releasing and all is back to normal.
I wonder if anyone else has this problem?
__________________
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ] -
bikehunter
Postby MrMPuk » Sun Feb 25, 2007 10:38 pm
That'll be one of your rear brakes jamming on then. You have to strip them and give them a clean. Either that or just park it in gear and don't use the handbrake.
Postby sc_BK » Sun Feb 25, 2007 11:27 pm
We have that on the old pug 405, repair would cost more than it's worth so we just park in gear :P
sc_BK
Postby motorwise » Sun Feb 25, 2007 11:38 pm
they do sometimes jam on these if left unused - strip the drum off and have a look you may find the wheel cylinders have leaked on to the shoes - if so then you'll have to replace them
good luck
http://www.motorwise.net
motorwise
Postby steamdrivenandy » Mon Feb 26, 2007 9:10 pm
It's just started to happen to mine.
I didn't drive it over this last weekend and I washed it as well but when I reversed out of the drive this morning there was a resounding 'THUNK' from the rear which could only have been the or a brake releasing (I hope).
Not a good thing to happen on an 8 month old van with only 8k on the clock.
Horizons Unlimited Innovation 1 - Best Transit in Show
steamdrivenandy
Postby Nathan_Cardiff » Mon Feb 26, 2007 11:04 pm
you lot are jinxes. its recently started on mine too... i just drag the back wheels down off the drive. they soon release :wink:
52 SWB Transit
Nathan_Cardiff
Postby xbox360 » Tue Feb 27, 2007 9:08 pm
Mine sticks on too but only if i have been driving in the rain the day before.
xbox360
Postby Nighthawk » Tue Feb 27, 2007 10:40 pm
if the handbrake sticks after standing in cold damp weather, it's usually a sign of excessive brake dust build up inside the drum.
If the brake won't release, turn off the engine...stick it in gear and give the back plate a quick clack with a knocking stick.
thats usually enough to release it.
Transit.........Job done
Nighthawk
Sticking Brakes
Postby Dan T » Wed Feb 28, 2007 2:14 am
That happened to my works van mk6 2004 04 - 85 280 mwb. Because its on autolease the rac came and fixed it, he used a big hammer and wacked the drums twice, Sorted.
Although i've never had that problem with my 2002 02 mk6.
Dan T
Postby Nathan_Cardiff » Wed Feb 28, 2007 9:33 am
Thats handy owning and driving for a living similar vans, i bet yours never needs any parts replacing :wink: :wink:
52 SWB Transit
Nathan_Cardiff
Postby bikehunter » Wed Feb 28, 2007 11:09 pm
Wow, thats a lot of replies! Since that last time I wrote about it ,it hasn't happened!
Thought it might have been a clutch sticking as forgot to mention that it happened when I started the van without depressing the clutch pedal.
__________________
bikehunter
Postby Azer van man » Wed Feb 28, 2007 11:38 pm
it used to happen to my old lwb 350 but only when it had p---ed down and i'd been through alot of suface water i was told that bacause of the excessive water it can cause the rear shoes to swell i just used to rev the girl up and go for it leaving 5oo miles worth of rubber on me drive :!: :!: :!:
Azer van man
Postby stuartrobbie » Fri Mar 02, 2007 1:32 am
happens with my X reg mk6 and like mentioned on here, happened with my puggy 405 too.
i find if you put it in reverse and start moving a bit quicker than normally(well most people) it will clunk off and be fine.
stuartrobbie
