2002 lpg poor idle / missfire
Postby martin lewis » Mon Feb 26, 2007 9:38 pm
can anyone help i have 2 vans with the same problems , rough idle and low rev misfires ,no fault codes on either vehicle ,coils , plugs ,leads compressions etc all tested ,injectors all working no air leaks , only clue is spark plugs look like the mixture is very weak , 02 sensors switching OK any advice appreciated
martin lewis
Postby MrMPuk » Mon Feb 26, 2007 11:26 pm
Do they run okay on petrol?
dual fuel proplems
Postby martin lewis » Tue Feb 27, 2007 7:37 am
no they are slighty worse on petrol
martin lewis
Postby MrMPuk » Tue Feb 27, 2007 9:23 am
When were they last serviced?
Postby martin lewis » Thu Mar 01, 2007 10:30 pm
both have full dealer history all up to date , both vehicles built in same month , further testing points to ecu under fueling ,i will post any findings
martin lewis
update on dual fuel problems
Postby martin lewis » Thu Mar 08, 2007 9:35 pm
it looks like a fueling problem , the weak mixture is causing the coils to over work trying to fire the weak mixture , both vehicles at dealer now, seeing the trouble with the new models i am glad of my 1987 DI , most complicated electrical device its got is the radio !!
martin lewis
