starting problems
starting problems
Postby 2.4 durashift 2003 » Mon Mar 05, 2007 8:53 pm
hi.
i fit new flywheel, new clutch and new starter motor in my van 03 reg 2.4di lwb.
now my problem is sometimes the starter motor don't turn (just selanoide noise). in 10 times 3 or 4 don't turn. Jump start with leads, fine. today i change batterie (put stronger one) but i still have the same problem. now in 10 times 2 or 3 don't turn starter motor.
when i put jump leads always turn and start
anyone can help me?
Faulty starter motor?
thanks
2.4 durashift 2003
Postby MrMPuk » Mon Mar 05, 2007 9:10 pm
Bad connections on the starter or bad earth to the engine maybe.
Postby Nighthawk » Mon Mar 05, 2007 9:14 pm
i'd go with poor connections too, sounds like the vehicle is using the slave vehicles electrical system to run the starter.
Transit.........Job done
Nighthawk
