transit clocks
transit clocks
Postby loot » Fri Nov 08, 2013 11:14 am
Just wondering if i can ask anyone what the idea is, i used to mess about with clocks on older fords like converting standard fiesta mk1/2 into xr2 with tacho etc, also converted a mk5 escort dash and clocks into mk6/7 latest type, that was fun lol.
Question is, i know i have to keep the brain from my van clocks but can i change the dials etc, do they have 3 pins to them that draw the same power/frequency?
In essence can i get say a set of Mondeo/focus clocks and make a fancy Frankenstein clock without confusing mine?
I could use my housing and circuit/membrane and manipulate the new dials to fit. :o
Haven't had my clocks out yet so have no clue of the arrangement.
Other thing is will the calibrations of said dials be out?
Thanks :wink:
Ids map here
loot
Re: transit clocks
Postby ake » Fri Nov 08, 2013 9:42 pm
I reckon you need to try it and find out ;)
Re: transit clocks
Postby limitedblack » Fri Nov 08, 2013 9:50 pm
loot34 wrote:Just wondering if i can ask anyone what the idea is, i used to mess about with clocks on older fords like converting standard fiesta mk1/2 into xr2 with tacho etc, also converted a mk5 escort dash and clocks into mk6/7 latest type, that was fun lol.
Thanks :wink:
They are stepper motors now, I've had mine to bits and there is next to nothing you can do. Can't even get the needles off.
Happy Easter
limitedblack
Re: transit clocks
Postby loot » Fri Nov 08, 2013 9:56 pm
Ids map here
loot
Re: transit clocks
Postby richgold » Sat Nov 09, 2013 9:23 am
I have the lockwood white dials in mine. Far better than the original ones.
I was just looking at thesefocus clocks and wondered... are they the same size as the mk7 Transit clocks and would that silver surround thingy from inside the fascia slot in? I might have a go at that.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Re: transit clocks
Postby loot » Sat Nov 09, 2013 10:28 am
Does look similar doesn't it, i do find the transit clocks a little bland :( plus i have to look under the steering wheel to see the indicator arrows if I'm not sure I'm indicating :roll: I'm hoping a cmax wheel and some speedo bajazzling will be all that's needed. :P
Ids map here
loot
Re: transit clocks
Postby limitedblack » Sat Nov 09, 2013 11:46 am
Bling it up a bit
Happy Easter
limitedblack
Re: transit clocks
Postby richgold » Sat Nov 09, 2013 3:27 pm
What are those four white things in front of your clocks?
F1 shift lights????
richgold
Re: transit clocks
Postby loot » Sat Nov 09, 2013 3:52 pm
I'd say frosted standard leds but what are they for? :wink:
I think every time he knocks someone over they light up 1 at a time this indicating a score, points wise do we agree 1 for a regular, 2 for a jay walker, 3 for an oap in a electric buggy, 4 for a group of cyclists?
:wink: :lol:
Ids map here
loot
Re: transit clocks
Postby limitedblack » Sat Nov 09, 2013 4:09 pm
I've bugged BJT's lime, as he gets closer they go from yellow (safe distance), to flashing red (he's here) :shock:
No not really ;). Just there to tell me if I have anything switched on with my remote key fob, as I have a few extra LEDs here and there, but can't tell from inside if they are on.
Happy Easter
limitedblack
Re: transit clocks
Postby richgold » Sat Nov 09, 2013 4:34 pm
Whats that hole inbetween your rev counter and speedo for limitedblack? I don't have that on mine, although I do have more fuel by the looks of it :)
richgold
Re: transit clocks
Postby limitedblack » Sat Nov 09, 2013 4:50 pm
richgold wrote:Image
Warning light, mine has the "posh" trip computer with stalk controls. Hence no knobs for clock and trip.
Happy Easter
limitedblack
Re: transit clocks
Postby loot » Tue Nov 19, 2013 1:19 am
Right, got my eye on some clocks, just wondering if anyone can help, the clocks i have seen don't have the 2 press buttons and do have the info circle in the centre, so i take it they are the top speck ones?
Next question is, if i get the indicator stalk that has the menu buttons, will i be able to control the clocks? Do i need to configure the clocks in ids to work?
Also i have seen 2 types of indicator switch, mostly for the focus, but 1 has the rubber menu wheel where as the other has lugs on it, I'd prefer that type but does it matter which 1 i need?
Lastly the mileage on the clocks wants to be the same as mine, i know ids can be used to increase the miles but if they are higher than mine does anybody know anyone who can set the miles to what i have on mine?
Thanks for any ideas. :D
Ids map here
loot
Re: transit clocks
Postby limitedblack » Tue Nov 19, 2013 7:29 am
I thought clocks are the same as pump and ECU, that's to say they are fixed to your vehicle and can't be swapped? IDS or Martyn may get over this. Btw yes top spec no buttons.
Happy Easter
limitedblack
Re: transit clocks
Postby ake » Tue Nov 19, 2013 8:06 am
loot34 wrote:Right, got my eye on some clocks, just wondering if anyone can help, the clocks i have seen don't have the 2 press buttons and do have the info circle in the centre, so i take it they are the top speck ones?
Transit stalk has the lugs on it.
Pretty sure the clocks will plug and play, except the temp sensor which needs wired and calibrated on ids.
Yes they sound like full spec clocks
