BCM replacement
BCM replacement
Postby bar891 » Tue Nov 26, 2013 12:33 am
2008 Ford Transit 2.5 diesel
Replaced BCM with new genuine unit
Programming with genuine ids & software
When trying to initialize module, it says it can't read as built data
I downloaded as built data & is in the correct folder in ids but IDS still can't find it
Am i doing something wrong?
Many Thanks
bar891
Re: BCM replacement
Postby v8dave » Tue Nov 26, 2013 9:33 am
I don't think a 2008 will have a 2.5 engine.... :?
IDS is probably trying to read the as built from the BCM, which does not have it. There is I believe a backup copy in the instrument cluster. I don't think the problem is reading the version on the pc.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: BCM replacement
Postby bar891 » Sat Nov 30, 2013 1:43 am
is there a way i can force it to read the backup copy?
bar891
Re: BCM replacement
Postby tranny1978 » Sat Nov 30, 2013 9:54 pm
If the BCMii has to be replaced for any reason, the backup ccc data stored in the Instrument Cluster must be programmed into it.
Select <Program the new master module….from the backup module.>. Press the tick
Follow the instructions on the IDS. The application will retrieve the vehicle data and then download it to the new BCMii
tranny1978
Re: BCM replacement
Postby Boonjason » Wed May 25, 2022 8:14 pm
Thanks tranny1978 for the info I will give it ago tomorrow
Boonjason
Re: BCM replacement
Postby knobby1 » Wed May 25, 2022 8:35 pm
Boonjason wrote:Thanks tranny1978 for the info I will give it ago tomorrow
Holly thread resurection Batman.. :mrgreen:
Thread is 9 years old and "tranny1978" hasn't been back on here since Jan 22 of 2014.
Re: BCM replacement
Postby Boonjason » Thu May 26, 2022 1:29 pm
So tranny1978 I take it is in module programming
Boonjason
Re: BCM replacement
Postby knobby1 » Thu May 26, 2022 9:28 pm
Boonjason wrote:So tranny1978 I take it is in module programming
Once again..."tranny1978" hasn't been back on here since Jan of 2014.
