bleeding fuel system
Postby karl » Thu Nov 28, 2013 6:09 pm
Their must be a easy way to bleed these systems
Am currently working on a 55 plate 2.0 tddi
I've changed the pump for a new recon pump and it just won't go n got codes p1665, po149 and another
It was the crank sensor not connected after taking the timing pin out
Now cleared all codes but still none start
An before everyone says yes it was a virginesed pump and followed the book to programming it
karl
Tranny Lover!!!
Re: bleeding fuel system
Postby Jamysumm » Thu Nov 28, 2013 6:12 pm
Nope, just bleed it then it will start. The time it will take to get it to start without bleeding it properly will be alot longer than just doing it right
Jamysumm
Postby karl » Thu Nov 28, 2013 6:53 pm
Whats your method of bleeding these ?? Jamy
karl
Tranny Lover!!!
Postby Jamysumm » Thu Nov 28, 2013 8:04 pm
There's a thread here somewhere thats the way I do it I'll go see if I can find the link bud
Jamysumm
Postby angeleye » Fri Nov 29, 2013 4:24 am
After filling with filter with diesel and tapping it to get any bubbles out tap fill tap fill...replace filter take rear left pipe of filter housing put pipe in a large bottle turn over as soon as it starts replace pipe
angeleye
Postby karl » Fri Nov 29, 2013 7:51 am
angeleye wrote:After filling with filter with diesel and tapping it to get any bubbles out tap fill tap fill...replace filter take rear left pipe of filter housing put pipe in a large bottle turn over as soon as it starts replace pipe
Will try it normaly I use a bulb and pipe but still I think it has a major air lock running doing the system will have another go this morning battery wasn't that clever either so put that on charge last night when left site/yard
karl
Tranny Lover!!!
Postby karl » Fri Nov 29, 2013 5:47 pm
This is now running after towing it in 3 rd gear from start didn't tow long but its running
Now and I get paid for the job simples :D
karl
Tranny Lover!!!
Postby Guy88 » Fri Nov 29, 2013 11:30 pm
Grenade pump inline between filter and pump. Remove return and force fuel thru until it flows out. Re fit return. Crack injectors. Pump until fuel flows out with no air. Turn engine over by hand and pump again. Tighten injectors and start engine
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby karl » Sat Nov 30, 2013 8:56 pm
Guy88 wrote:Grenade pump inline between filter and pump. Remove return and force fuel thru until it flows out. Re fit return. Crack injectors. Pump until fuel flows out with no air. Turn engine over by hand and pump again. Tighten injectors and start engine
hi guy thanks for the advice mate i tried the bulb etc but still no joy
i seem to be getting more and more jobs for transits at the min, am pulling a engine out tomorrow off one the rod straight threw the block :D
karl
Tranny Lover!!!
Postby karl » Sat Nov 30, 2013 9:26 pm
also i have the the pump cog holding tool but didn't know how to use it so just took timing cover off lol
karl
Tranny Lover!!!
