Vxt 75 gearbox
Vxt 75 gearbox
Postby andymudge » Wed Aug 06, 2014 5:29 pm
According to the dealer this is the box that is in my 2003 100bhp fwd. I am going to bight the bullet and replace the box as I've had 3 pairs of cables this year and 2nd gear still crunches like an arse. My question is this , all the boxes I see are classed as mxt75 4 or 5 bolt , there are vxt75 available from overseas but these cost thousands , is there an alternative box or code perhaps I can use please ?
andymudge
Re: Vxt 75 gearbox
Postby TheTransitCentre » Wed Aug 06, 2014 5:37 pm
From memory, because I'm not in the yard to ask, the 4 pin changed to 5 pin in 2003 so you'll need to check.
Good second hand one's fetch £250-300. Reconditioned are £480 both on an exchange basis.
Just a Newbie! Learning about Transits but I have some men who know nothing else. If you phone us just remember I'm a messenger.
www.thetransitcentre.co.uk
01384 240933 Please leave contact number. Mention this Forum or http://www.thetransitcentre.co.uk/html/contact.html
TheTransitCentre
Registered Trader
Registered Trader
Re: Vxt 75 gearbox
Postby andymudge » Wed Aug 06, 2014 6:10 pm
I can count the bolts np, but is the vxt and mtx the same thing ? Are you offering boxes at these prices ?
andymudge
Re: Vxt 75 gearbox
Postby Dan T » Wed Aug 06, 2014 7:15 pm
andymudge wrote:I can count the bolts np, but is the vxt and mtx the same thing ? Are you offering boxes at these prices ?
You'll get an MT75 for rwd and vxt75 for fwd available in 4 or 5 bolt.
There isn't a mxt75
Dan T
Re: Vxt 75 gearbox
Postby 75psT330lwb » Wed Aug 06, 2014 10:39 pm
wrong. there is an mtx75 but the vxt75 is an upgraded stronger box that replaced it, which they fitted to transits. mondeos use the mtx75 but its the same box fitting wise. unsure if it can cope with the extra load that it will be put through though if its fitted to a van. cant see why not.
Custom Ecoblue
75psT330lwb
Re: Vxt 75 gearbox
Postby andymudge » Thu Aug 07, 2014 12:53 pm
ok its the 4 bolt as defined by the number of bolt holes going into the mount on the engine block, for those like myself who didnt know how to check.
Does any one have one ?
andymudge
Re: Vxt 75 gearbox
Postby paul2012 » Thu Aug 07, 2014 7:38 pm
Transit mk6's FWD were fitted with VXT-75 5 Speed gearboxes with a ratio of either 4.54 or 4.23
mk6 2.4 RWD fitted with MT-75 5 speed gearbox or MT82 8)
If you're are looking for VXT-75 box, here's a couple
1C1R-7002-BF 2001 2.0Di Ratio 4.54 :arrow:http://www.ebay.co.uk/itm/FORD-TRANSIT- ... 41816570f5
1C1R-7002-BL 2004 2.0Di 85/100ps T260/T280/T300 series Ratio 4.54 :arrow:http://www.ebay.co.uk/itm/2004-FORD-TRA ... 5b03069a0e
a VXT-75 gearbox is also fitted to 2001-2006 Galaxy 2.0/2.3 EFI (Petrol) unfortunately no good for the mk6, different clutch/bell housing
Ps- Don't confuse VXT-75 with MXT-75 boxes fitted to other vehicles. For example a Focus Mk1, Transit Connects, C-Max. Mondeo mk3/4 also have MTX-75 FWD 5 Speed gearboxes - They will NOT fit Transit mk6's :!:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: Vxt 75 gearbox
Postby Dan T » Thu Aug 07, 2014 7:54 pm
75psT330lwb wrote:wrong. there is an mtx75 but the vxt75 is an upgraded stronger box that replaced it, which they fitted to transits. mondeos use the mtx75 but its the same box fitting wise. unsure if it can cope with the extra load that it will be put through though if its fitted to a van. cant see why not.
vxt75 in fwd mk6's
There is no MXT75 ! There is however a MTX75 built for fwd, but this was never fitted to a mk6 transit.
MT75 (2000 version) was fitted to the 2.4's.
Dan T
Re: Vxt 75 gearbox
Postby 75psT330lwb » Sun Aug 10, 2014 9:11 am
who said there was an mxt75 :roll:
Custom Ecoblue
75psT330lwb
Re: Vxt 75 gearbox
Postby Dan T » Sun Aug 10, 2014 10:28 pm
75psT330lwb wrote:who said there was an mxt75 :roll:
If you read the first post :roll: :wink:
Dan T
Users browsing this forum: Bing [Bot], Google [Bot]
