Adding 3 seats in back
Postby Dan T » Wed Apr 25, 2007 3:00 pm
2002 02 280 swb 2.0L
Hi all
I'm thinking of adding 3 seats into the back. Does anyone know the best way of doing this ?
Dan T
Postby Nathan_Cardiff » Wed Apr 25, 2007 3:19 pm
Without looking i wouldnt be sure, but isnt the fuel tank in the way underneath if your planning on putting them behind the front seats :?:
I supose if you weld them in or bolt them in the tank would have to be moved :?:
52 SWB Transit
Nathan_Cardiff
Postby MrMPuk » Wed Apr 25, 2007 3:20 pm
Move the tank?
Postby Nathan_Cardiff » Wed Apr 25, 2007 3:23 pm
MrMPuk wrote:Move the tank?
you wouldnt want to weld the seats in with the tank below, nor drill holes through the floor? too risky surely
52 SWB Transit
Nathan_Cardiff
Postby MrMPuk » Wed Apr 25, 2007 3:30 pm
Maybe remove the tank but not move it!
Postby Nathan_Cardiff » Wed Apr 25, 2007 3:32 pm
MrMPuk wrote:Maybe remove the tank but not move it!
thats what i meant
52 SWB Transit
Nathan_Cardiff
Postby Lee J » Wed Apr 25, 2007 3:54 pm
you dont have to. I've just put some in. have you checked if the holes are already there? Mine were but nowhere close to the tank
Transit Van - Gonna cost me a marriage if I'm not careful.
Lee J
Postby Dan T » Wed Apr 25, 2007 6:05 pm
I'm going to have to lift the plywood lining and look. Ill post my results.
If there are no holes, how difficult will it become to add the seats ? Dont know if i fancy removing fuel tanks or anything else as i just dont have the time to do it.
Dan T
Re: Adding 3 seats in back
Postby Luke » Wed Apr 25, 2007 7:04 pm
Dan T wrote:I'm going to have to lift the plywood lining and look. Ill post my results.
you could weld plates in from the top ive done it this way with my rear(3rd row) seats - the important part is the seat belt mount as than takes the strain in an accident :!: but if the belts are on the seat then the seat mounts :D
Postby Dan T » Thu Apr 26, 2007 9:15 pm
If there are marked bolting points on the floor is it just a case of drilling them through and bolting straight through ? or is there a little more to it ?
Dan T
Postby Dan T » Wed May 09, 2007 8:03 pm
lifted my ply lining and found the bolting points.
Looking at these seats
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=012&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=220109479964&rd=1&rd=1
How would i fit these ?
Dan T
Postby becky » Wed May 09, 2007 11:12 pm
i`ve just taken 3 seats out....
the were just bolted throught the floor, with a small square plate before the nut as a bit of re-enforcement.
jumbos do it standing up....
becky
I'm a hairy arsed male!!
Postby Dan T » Thu May 10, 2007 12:21 am
sounds fairly simple (famous last words) :lol:
Dan T
Postby Dan T » Sun May 13, 2007 11:49 pm
Got my seats now :D
Its a bench seat which has the seatbelts on the frame.
Do the seats need to be bolted in 4 places ? as i can only see 2 unless the seats are to face to the rear where there are 4 holes availible.
Dan T
Postby MrMPuk » Sun May 13, 2007 11:54 pm
You will need to use 4 bolts.
Users browsing this forum: dumper
