Noise when braking!!
Postby handyandy733 » Sun May 06, 2007 7:43 pm
I have a great T280 hi-roof 2002 transit that I am extremely pleased with, this is my 4th transit. I recently noticed a noise like a low drone when I brake and come to a stop, I immediately thought it was pad wear and renewed these and the disc's and thought all was well. Now about 2k on, the noise is coming back, surely the pad's can't be the problem again. Any suggestions? Thanks.
handyandy733
Postby MrMPuk » Sun May 06, 2007 7:47 pm
Were the pads worn when you replaced them last time?
Have you checked them since it started again?
Postby mike.48 » Sun May 06, 2007 7:49 pm
hi did you change wheel bearings.
mike.48
Postby Nighthawk » Sun May 06, 2007 7:59 pm
would you describe it as a low graunch noise when braking with moderate force to a stop from say 20mph?
If so, it's probably a normal noise resulting from the metal content in the friction materials used to make the pads.
Nothings been the same since we lost asbestos :D
Transit.........Job done
Nighthawk
Postby handyandy733 » Sun May 06, 2007 8:20 pm
The pads were a bit shot when they were changed, well so i'm told. I got 12 months warranty on the van so I took it to the dealer. 1st time they said it was due to excessive build up of dirt, 2nd time I took it they replaced pads and disc's, even though these were replaced 8 months previously when I bought the van, and now I think i'll give them a bit of a kick up the hole, because every time I take it I loose a days pay (I'm self-employed).
handyandy733
Postby 100 T280 » Sun May 06, 2007 9:39 pm
The noise you describe does sound like wheel bearings to me, a common failure on mk6s. If it's one side that's going, it will show more when steering in the opposite direction (ie, steering to the left, noise comes from o/s hub). The o/s bearing is shot on mine and although it is noisy all the time, it is worse whilst braking due to the load on the hub.
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby handyandy733 » Mon May 07, 2007 2:24 pm
Thanks for all your help guys, very much appreciated. I'm not going to touch the van myself until the warranty is out, then the dealer can go swivel for my business! I hate taking any vehicle to a garage, rarther have a go myself, at least then you learn a bit! I just wanted to see what people thought it could be so I have a little more ammunition to give the dealer. Thanks again for all your help. Safe drivin'
handyandy733
Postby jb4rrett » Tue May 08, 2007 8:47 pm
just got mine back from fords, they changed the disks and pads earlier this year and now is vibrating and making noise under braking they said the pad was not on square and was hitting the carrier? Does seem better now though.
jb4rrett
Users browsing this forum: Bing [Bot], meh
