Wheel Align a Mk6
Wheel Align a Mk6
Postby emmsee » Sun Feb 22, 2015 3:29 pm
With no knowledge I took my 2002 MK6 rwd Cab Chassis 2.4 tddi to a tyre shop for a wheel alignment - she was pulling left.
2 1/2 hours later I drove away with her still pulling left - no cost for failing.
I now find, from the Haynes manual, that Transits can't be wheel aligned.
If not, how do I eradicate the pulling left?
cheers
emmsee
emmsee
Re: Wheel Align a Mk6
Postby ake » Sun Feb 22, 2015 6:25 pm
First, throw away the Haynes manual, it's wrong.
Then check all suspension components, broken coils will cause pull, as will collapsed bushes, bent bottom arms etc etc
Postby paul2012 » Sun Feb 22, 2015 6:25 pm
Checked 2 bushes on lower suspension arm :idea:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby binge » Sun Feb 22, 2015 7:03 pm
If all of the above seems to be okay, do your self a favor and unbolt both wheels.
Bolt them back on the opposite sides.
See how you get on. If it starts to pull the other way, then you have a tyre issue. Sometimes a tyre with a considerably softer sidewall construction can cause a natural pull.
binge
Postby mjsroofing » Sun Feb 22, 2015 9:25 pm
Why couldn't he do the tracking, what was he using, laser tracking or the computerized ones.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby blue estate » Sun Feb 22, 2015 9:38 pm
Funny my garage could track my jumbo
blue estate
Postby mjsroofing » Sun Feb 22, 2015 10:15 pm
The newer machines don't always get it right but the old ones, well you can't really go wrong.
mjsroofing
Postby DINGLE » Sun Feb 22, 2015 11:16 pm
Might be worth having rear axle and u bolts checked aswell
DINGLE
Postby mjsroofing » Sun Feb 22, 2015 11:35 pm
Would seen that when measuring the offset , still check of course,
Did they tell you if it had any offset.
mjsroofing
Postby emmsee » Mon Feb 23, 2015 5:28 am
Thanks for all your suggestions.
I have the Transit going in on Thursday for new Injectors and have given the mechanic your list of suggestions re the pulling to the left to test.
Will let you know the outcome.
cheers
emmsee
emmsee
Postby coacher » Mon Feb 23, 2015 11:04 am
Are the tyres on the from the same both sides? Also worth checking the tyre pressures and tread depth.
coacher
Postby emmsee » Sat Jul 04, 2015 4:14 pm
Changed the tyres to opposite sides and hey presto - not pulling any more!
Thanks everyone for your advice.
emmsee
