Is my van a Mk6 or Mk7?
Postby combat_chef » Sat Mar 21, 2015 3:00 pm
According to the log book, I have a Transit 110 T280 FWD, engine capacity 2198cc. Max Power Net (Kw) = 81. It's registered on a 56 plate but first registered in Feb 2007. How do I find out what Mk it is? I need to replace the drivers seat as some of the welded joints on the support/adjustment/slider mechanism have completely broken loose and I was advised it would be better to replace the entire seat rather than try to repair the broken welds.
Advice and opinions would be welcome. TIA.
combat_chef
Re: Is my van a Mk6 or Mk7?
Postby Mr RVM » Sat Mar 21, 2015 3:03 pm
Mk7 :wink:
Mr RVM
Postby ake » Sat Mar 21, 2015 3:14 pm
As said, you have a Mk 7, but the Mk 6 seat fits the same, although the fabric is different
Postby spospe » Sat Mar 21, 2015 9:43 pm
combat_chef wrote:According to the log book, I have a Transit 110 T280 FWD, engine capacity 2198cc. Max Power Net (Kw) = 81. It's registered on a 56 plate but first registered in Feb 2007. How do I find out what Mk it is? I need to replace the drivers seat as some of the welded joints on the support/adjustment/slider mechanism have completely broken loose and I was advised it would be better to replace the entire seat rather than try to repair the broken welds.
MK7 Transits have a high level brake light on the nearside rear door and also have clear glass over the indicators at the rear (the bulbs are yellow). These are the quick and easy ways to distinguish between a MK7 and a MK6 when viewed from the back. From the front the MK7 has the largest "Ford" badge in the entire Ford range on its grill and the headlamps are stacked vertically instead of horizontally like on a MK6.
spospe
Postby ake » Sun Mar 22, 2015 1:19 pm
Mk 6 - gear lever on floor
Mk 7 - gear lever on dash.
Postby combat_chef » Sun Mar 22, 2015 9:28 pm
Cheers lads for all the info, very helpful to a tranny virgin lol :-)
combat_chef
Postby ABA » Mon Mar 23, 2015 6:44 pm
you carnt really go on front end or rear lights as they can be changed to make the mk 6 look like a mk 7 easiest is gear stick mk 6 floor mount mk 7 dash mount
ABA
Postby Bjackson36 » Fri May 07, 2021 8:12 pm
Is my van a Mk6 or 7??
Has anyone used these seats?
Will they work?
https://bm-camperinteriors.glopalstore. ... -2000-2013
thanks
Bjackson36
