Cutting Out & Intermittent Non-Starting
Postby JamesAndHayley » Sun May 10, 2015 7:53 pm
Couple of odd issues but is preventing us using the van, these have got progressively worse over the course of a week.
The coil light began flashing
Started the van Tuesday, got it going for about 30 seconds then it cut out. Couldn't start it again despite trying occasionally for 2 days. The coil light did not go out and would flash on and off every time we attempted to start the engine.
Cutting Out
4 days later, got in to try it and started straight away. Took it for a drive and as we were coming down a hill, very little if any acceleration, it cut out. There was electrical power, but no fuel delivery.
We sat for 20 minutes, randomly tried it again and managed to get it back home.
Any suggestions what's going on?
Van is Mk6 2.4 diesel duratorq 2001
TIA, James
JamesAndHayley
Re: Cutting Out & Intermittent Non-Starting
Postby andypdq » Sun May 10, 2015 9:01 pm
Odds are, electronic injection pump failure. :( You need to get the fault codes read.
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
Postby JamesAndHayley » Sun May 10, 2015 9:09 pm
Thanks for the reply. Could be, it dies randomly, under load or at idle. Also it takes about 30 seconds with the ignition on before the lift pump starts to prime itself. My gut tells me this little electric pump is the source of the problem.
JamesAndHayley
Postby bambi mk 1 » Sun May 10, 2015 9:31 pm
Unless its a 125 it wont have an electric lift pump.As Andy says get codes read but in my experience once a pump dies once its pretty much terminal.I think you may have a crank sensor problem but read the codes first.
bambi mk 1
Postby JamesAndHayley » Mon May 11, 2015 6:14 pm
Thanks for the speedy reply. Do you mean 125hp? Couldn't say. There is What seems to be a small pump attached to the fuel filter housing in the engine bay. I have a diagnostic tool on order. Where Abouts is the crank position sensor located?
JamesAndHayley
Postby andypdq » Mon May 11, 2015 9:04 pm
Put yor reg no, or vin in here: https://www.etis.ford.com/vehicleRegSel ... 9.fcvas504
It will tell you the spec of your van.
Crank sensor is on the right hand side of the bell housing, behind the exhaust manifold, on the 2.4. :D
andypdq
Postby JamesAndHayley » Sat May 30, 2015 10:58 am
Ok, so it's been diagnosed by a Ford garage. They say is the fuel infection pump and want 2000 euro to fit a new one. I'm not convinced with A. That ridiculous price and B. Their diagnosis. I still think it's an electrical fault.
I've had a second opinion who tells me that when a fip goes it's dead, it won't run intintermittently, it just won't pump.
I've done some research and cleaned the earth strap under the drivers seat, no change. Tried a different key, no change.
I am however starting to believe it's the immobiliser. The little red light on the clock starts flaflashing whenever the ignition is on and I understand this indicates the immobiliser is engaged. This would also throw up a fuel pump fault code.
Anyone have any ideas?
JamesAndHayley
Postby Punto443 » Sat May 30, 2015 11:05 am
Check the wiring loom that goes to the fip, there been a few cases where the loom chaffs on the starter and can cause intermittent faults,
Rare, but worth a try before condemning a pump :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby ake » Sat May 30, 2015 2:39 pm
What were the recorded fault codes?
Postby JamesAndHayley » Tue Jun 02, 2015 4:09 pm
Couldn't get my diagnostic tool to connect to the van. I don't know what codes the garage had, they just told me fuel pump.
This afternoon I cracked of the injectors and cranked it over. There is diesel at every one. Would it still pump to the injectors of it was knackered?
JamesAndHayley
Postby andypdq » Tue Jun 02, 2015 8:25 pm
If you loosen the injector pipes from the top of the injectors, it should spray diesel everywhere when you crank it, if your pump is healthy, if you have a feeble dribble, then odds are, it's the pump. :(
andypdq
