Wiring diagram for lights
Postby Yeti » Thu May 14, 2015 9:03 am
My Mk6 tipper has no sidelights, tail lights, side marker lights, number plate lights or instrument panel lights.
As they're all separate fuses, I figured it must be the switch, so I removed the switch and tried it on one of my Mk6 vans, and the switch is fine.
I've checked all the bulbs, still nothing.
Nothing obvious in the wiring behind the switch, so does anyone have a copy of a wiring diagram for the light switch/light circuit please so I can hunt the problem down please? Thanks.
Yeti
Re: Wiring diagram for lights
Postby APH » Thu May 14, 2015 10:57 pm
The light switch is fed from one 20a fuse, fuse 224 in the passenger cubby hole box, depending how you look at it, it's either the third or the fifth fuse in from the left at the top (nearest windscreen)
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby Yeti » Sat May 30, 2015 12:31 pm
I've checked the fuse already and it's fine - do you know which wire on the switch it goes to please so I can check for continuity? Thanks.
Yeti
Postby wojciech » Sat May 30, 2015 4:23 pm
It is orange/yellow cabel on the switch, pin 11.
If on pin 11 is constantly +12V and no lights - switch is kaput. :cry: It is often the case that light switch is broken.
wojciech
Postby Yeti » Sun May 31, 2015 2:07 pm
I already took the switch out and tried it on one of my vans - and it worked fine. I'll check that out - thanks.
Yeti
Postby Yeti » Sun May 31, 2015 4:35 pm
Thanks guys - there is no pin 11 on the headlight switch, but the wire between fuse 224 and the "P" terminal was broken. Now all working again. Thanks.
Yeti
Postby paul2012 » Sun May 31, 2015 11:55 pm
Yeti wrote:Thanks guys - there is no pin 11 on the headlight switch, but the wire between fuse 224 and the "P" terminal was broken. Now all working again. Thanks.
Transit mk7 Exterior lighting wiring diagram can be downloaded here :arrow: https://www.sendspace.com/file/wdsf0v 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
