Mk6 transit t280 locking issue
Postby trebor1989 » Sun May 17, 2015 7:06 pm
Hi all,
Have searched for this for a while just so i didnt waste anyones time, if anyone can put me onto a thread i would appreciate it but here's my problem.
Van was parked up for 18 months came back to it mot'd it etc etc lost fob, found fob, fob was all coroded into itself unuseable bit of wd40 got buttons clicking still wouldnt work so bought fleabay fob. couldnt/still cant locks to cycle on van to reprogramme new fob, changed module under glove box, checked all the fuses that i could see/find in the van all ok. so i am now stuck cannot find the problem if anyone has any clues/solutions they would be much appreciated.
Many Thanks
Rob.
trebor1989
Re: Mk6 transit t280 locking issue
Postby Brains_transit » Sun May 17, 2015 7:29 pm
There's 2 fuses at the steering column. Does the cl work with the key
Brains_transit
Postby trebor1989 » Sun May 17, 2015 7:31 pm
no doesnt work with lock and checked the 2 blues they are fine.
trebor1989
Postby trebor1989 » Mon May 18, 2015 7:56 pm
any other ideas anyone?
trebor1989
Postby trebor1989 » Tue May 19, 2015 8:24 pm
right so now ive got the module to start clicking by of all things the f****ng interior lights had no bulbs in so wired them on but as i say i now do the 8 times on and off and the module just clicks the module i got from the breakers does nothing any ideas?
trebor1989
Postby loot » Tue May 19, 2015 8:46 pm
Might be worth checking every fuse you can find, did you do the procedure exactly?
viewtopic.php?f=40&t=69421&p=1342420&hilit=mk6+key+fob+programming#p1342420
Also consider a faulty eBay fob?
And do you know whether the module is plug and play? I don't but might be worth thinking about? I vaguely recall Paul2012 saying they are tho :wink:
Ids map here
loot
Postby trebor1989 » Tue May 19, 2015 9:21 pm
checked every fuse and i have 3 fobs as i thought it was faulty complained to the company they sent me another and bought another from different seller just to be sure but apparently the fob has nothing to do with locks cycling. they should cycle regardless of faulty fob apparently. i assume they are plug and play will be back up the breakers but keep buying these bloody things not knowing wether theyre working or not is a nightmare.
trebor1989
Postby loot » Tue May 19, 2015 10:36 pm
Yes the locks should cycle, i posted that link above because a couple of members have had the same result as you with the locks not cycling etc.
I think that is your main thing to do is get them cycling And then it should be easy to pair the fob.
If it was sat for that long it could be a corroded wire or anything tho :-(
Next step would be testing for power etc.
Ids map here
loot
Postby Brains_transit » Tue May 19, 2015 11:23 pm
You could send me or someone local to you the central locking module and I'll tell you if it works. The fob has nothing to do with the cycle as the ignition cycle triggers the module. If the module is clicking it's trying to lock or unlock so there's a seized motor or wire fault or could be a bad earth
Brains_transit
