I'm losing quite a bit of power steering fluid on a Mk6 2002 90 T350.
The steering has been intermittently notchy with a binding feeling, even groaning at times, then it can be fine.
It still feels the same but I've noticed quite a lot of fluid under the van and the cross member under the steering rack is wet.
Will this be the steering rack that is leaking somewhere or maybe the steering pump?
Thanks,
Mark...
