Spray painting
Spray painting
Postby Jaymac » Tue May 26, 2015 11:57 pm
Hi, looking for some advice on painting two new front wings on my 2002 ford transit 350, I am just going to spray the wings but the paint on the doors and bonnet are flat how do I bring them up to the colour as the wings. I am going to use cellulose paint do I use a clear lacquer and if so will I coat the doors and bonnet with it.
Jaymac
Re: Spray painting
Postby loot » Wed May 27, 2015 9:29 am
What colour is the van?
Existing paint can be cut then polished.
I use a buffing machine and farecla g3 compounding paste and a little water. Then any polish but i have mer polish at the moment.
Lacquer is only for metallic colours.
Ids map here
loot
Re: Spray painting
Postby Jaymac » Wed May 27, 2015 10:05 am
The van is white, will I need to use a clear lacquer.
Jaymac
Re: Spray painting
Postby Jaymac » Wed May 27, 2015 10:07 am
Sorry did not see the bit about the lacqure in to much of a rush today.
Jaymac
Re: Spray painting
Postby loot » Wed May 27, 2015 10:37 am
Just half litre of diamond white should do, i use 2 pack but cellulose and thinners should be OK :-)
Don't forget to wait a little bit between coats and allow it to pool before spraying to a shine or you may get runs :wink:
(That's if you are using a gun not rattle cans)
Ids map here
loot
Re: Spray painting
Postby stevo » Wed May 27, 2015 11:22 am
Halfords diamond white is a good match, I used it with grey primer and its bang on. I would use a clear lacquer or topcoat though and leave it to harden
Formely ibanez2005
Your's is the new Ford Transit!
2003 100 T260 TDDi swb
stevo
Re: Spray painting
Postby bazw » Wed May 27, 2015 12:00 pm
If you have not bought the paint yet get single pack acrylic rather that celli, its far less work as it will not need buffing when dry to give a good shine and is almost as good as 2 pack acrylic without the poisonous hardener.
celli can react with the acrylic paint already on the van and give you a crazed wrinkled edge.
how are you spraying it btw
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Re: Spray painting
Postby Jaymac » Wed May 27, 2015 2:01 pm
I have bought the cellulose paint and I am going to try spray gun.
Jaymac
Re: Spray painting
Postby bazw » Wed May 27, 2015 2:25 pm
if new wings use thinners to remove the transit primer( crap stuff on when bought)
rub down with 320 grit to key
prime (celli primer), rub down to get it smooth
will need at least 3 coats of celli with a light rub down between coats when dry with fine wet and dry paper
then when fully dry will need wet flatting then buffing with lambswool mop to get the shine,
a lot of hard work
if just doing up your wings do a test spot as it can react.
2.4 duratorq 115 ps
A.R. 4.27
bazw
Users browsing this forum: Bing [Bot], metalworker0
