ake wrote:Swap the engines, the pumps are the same. The injectors may be different, I can't remember.
If you use the pump on the 75 then it will need coded to the van by someone with suitable diagnostic kit
stevo wrote:ake wrote:Swap the engines, the pumps are the same. The injectors may be different, I can't remember.
Needs the intercooler too
Isnt the map different?
Jonjonjon wrote:How can I tell if injectors the same or different? Any coeds part numbers on them,
All in all the tho block the same??? Head Pistons rods etc etc
ake wrote:stevo wrote:ake wrote:Swap the engines, the pumps are the same. The injectors may be different, I can't remember.
The inter cooler is already fitted to the 100ps van, as is the 100ps ecuJonjonjon wrote:How can I tell if injectors the same or different? Any coeds part numbers on them,
Block and head are similar enough!
Injectors may have part numbers on, check if they are the same, or just try it with the 75 injectors and if it's slow swap them
